CesiumVectorData::GeoJsonGeometryCollection Struct Reference
A GeometryCollection represents any number of GeoJsonObject objects. More...
std::vector< GeoJsonObject > geometries
 The GeoJsonObject values contained in this GeometryCollection.
std::optional< CesiumGeometry::AxisAlignedBox > boundingBox = std::nullopt
 The bounding box associated with this GeometryCollection value, if any.
CesiumUtility::JsonValue::Object foreignMembers
 Any members specified on this object that are not part of the specification for this object.
std::optional< VectorStyle > style = std::nullopt
 The style to apply to this object as well as any child object. If not set, the style of any parent object or the default style will be used.
static constexpr GeoJsonObjectType TYPE
 The GeoJsonObjectType for a GeometryCollection.
Definition at line 272 of file GeoJsonObjectTypes.h.
◆ boundingBox
std::optional<CesiumGeometry::AxisAlignedBox> CesiumVectorData::GeoJsonGeometryCollection::boundingBox = std::nullopt
Definition at line 287 of file GeoJsonObjectTypes.h.
◆ foreignMembers
CesiumUtility::JsonValue::Object CesiumVectorData::GeoJsonGeometryCollection::foreignMembers
Initial value:
std::map< std::string, JsonValue > Object
Definition JsonValue.h:73
Definition at line 296 of file GeoJsonObjectTypes.h.
◆ geometries
std::vector<GeoJsonObject> CesiumVectorData::GeoJsonGeometryCollection::geometries
Definition at line 281 of file GeoJsonObjectTypes.h.
◆ style
std::optional<VectorStyle> CesiumVectorData::GeoJsonGeometryCollection::style = std::nullopt
Definition at line 303 of file GeoJsonObjectTypes.h.
◆ TYPE
GeoJsonObjectType CesiumVectorData::GeoJsonGeometryCollection::TYPE
Initial value:
GeoJsonObjectType::GeometryCollection
Definition at line 274 of file GeoJsonObjectTypes.h.
