CesiumVectorData::GeoJsonMultiPolygon Struct Reference
A 'MultiPolygon' geometry object. More...
std::vector< std::vector< std::vector< glm::dvec3 > > > coordinates
 The list of Polygons making up this MultiPolygon. Each entry has equivalent rules to the coordinates property of a GeoJsonPolygon.
std::optional< CesiumGeometry::AxisAlignedBox > boundingBox = std::nullopt
 The bounding box associated with this MultiPolygon value, if any.
CesiumUtility::JsonValue::Object foreignMembers
 Any members specified on this object that are not part of the specification for this object.
std::optional< VectorStyle > style = std::nullopt
 The style to apply to this object as well as any child object. If not set, the style of any parent object or the default style will be used.
static constexpr GeoJsonObjectType TYPE = GeoJsonObjectType::MultiPolygon
 The GeoJsonObjectType for a MultiPolygon.
A MultiPolygon value contains multiple Polygon coordinate sets.
Definition at line 233 of file GeoJsonObjectTypes.h.
◆ boundingBox
std::optional<CesiumGeometry::AxisAlignedBox> CesiumVectorData::GeoJsonMultiPolygon::boundingBox = std::nullopt
Definition at line 247 of file GeoJsonObjectTypes.h.
◆ coordinates
std::vector<std::vector<std::vector<glm::dvec3> > > CesiumVectorData::GeoJsonMultiPolygon::coordinates
Definition at line 242 of file GeoJsonObjectTypes.h.
◆ foreignMembers
CesiumUtility::JsonValue::Object CesiumVectorData::GeoJsonMultiPolygon::foreignMembers
Initial value:
std::map< std::string, JsonValue > Object
Definition JsonValue.h:73
Definition at line 256 of file GeoJsonObjectTypes.h.
◆ style
std::optional<VectorStyle> CesiumVectorData::GeoJsonMultiPolygon::style = std::nullopt
Definition at line 263 of file GeoJsonObjectTypes.h.
◆ TYPE
GeoJsonObjectType CesiumVectorData::GeoJsonMultiPolygon::TYPE = GeoJsonObjectType::MultiPolygon
Definition at line 235 of file GeoJsonObjectTypes.h.
