CesiumVectorData::GeoJsonFeature Struct Reference
A GeoJsonFeature object represents a spatially bounded "thing." It is a collection of information that is possibly linked to a geometry object. More...
 GeoJsonFeature ()=default
 Default constructor.
 GeoJsonFeature (GeoJsonFeature &&rhs) noexcept=default
 Move constructor.
 GeoJsonFeature (const GeoJsonFeature &rhs)
 Copy constructor.
 GeoJsonFeature (std::variant< std::monostate, std::string, int64_t > &&id, std::unique_ptr< GeoJsonObject > &&geometry, std::optional< CesiumUtility::JsonValue::Object > &&properties, std::optional< CesiumGeometry::AxisAlignedBox > &&boundingBox, CesiumUtility::JsonValue::Object &&foreignMembers)
 Creates a new GeoJsonFeature with the given values.
GeoJsonFeature & operator= (const GeoJsonFeature &rhs)
 Copy assignment operator.
GeoJsonFeature & operator= (GeoJsonFeature &&rhs) noexcept=default
 Move assignment operator.
std::variant< std::monostate, std::string, int64_t > id = std::monostate()
 The "id" of this object. A Feature's ID is optional, but if specified it will be either a string or a number.
std::unique_ptr< GeoJsonObject > geometry
 The GeoJsonGeometryObject associated with this Feature, if any.
std::optional< CesiumUtility::JsonValue::Object > properties
 The set of additional properties specified on this Feature, if any.
std::optional< CesiumGeometry::AxisAlignedBox > boundingBox = std::nullopt
 The bounding box associated with this Feature value, if any.
CesiumUtility::JsonValue::Object foreignMembers
 Any members specified on this object that are not part of the specification for this object.
std::optional< VectorStyle > style = std::nullopt
 The style to apply to this object as well as any child object. If not set, the style of any parent object or the default style will be used.
static constexpr GeoJsonObjectType TYPE = GeoJsonObjectType::Feature
 The GeoJsonObjectType for a Feature.
Definition at line 310 of file GeoJsonObjectTypes.h.
◆ GeoJsonFeature()
CesiumVectorData::GeoJsonFeature::GeoJsonFeature ( std::variant< std::monostate, std::string, int64_t > && id,
std::unique_ptr< GeoJsonObject > && geometry,
std::optional< CesiumUtility::JsonValue::Object > && properties,
std::optional< CesiumGeometry::AxisAlignedBox > && boundingBox,
CesiumUtility::JsonValue::Object && foreignMembers )
idThe ID of the new feature.
geometryThe GeoJSON geometry object contained in this GeoJsonFeature, if any.
propertiesProperties attached to this feature, if any.
boundingBoxThe bounding box defined for this feature, if any.
foreignMembersAny foreign members defined on this object in the source GeoJSON.
◆ boundingBox
std::optional<CesiumGeometry::AxisAlignedBox> CesiumVectorData::GeoJsonFeature::boundingBox = std::nullopt
Definition at line 363 of file GeoJsonObjectTypes.h.
◆ foreignMembers
CesiumUtility::JsonValue::Object CesiumVectorData::GeoJsonFeature::foreignMembers
Initial value:
std::map< std::string, JsonValue > Object
Definition JsonValue.h:73
Definition at line 372 of file GeoJsonObjectTypes.h.
◆ geometry
std::unique_ptr<GeoJsonObject> CesiumVectorData::GeoJsonFeature::geometry
Definition at line 351 of file GeoJsonObjectTypes.h.
◆ id
std::variant<std::monostate, std::string, int64_t> CesiumVectorData::GeoJsonFeature::id = std::monostate()
Definition at line 346 of file GeoJsonObjectTypes.h.
◆ properties
std::optional<CesiumUtility::JsonValue::Object> CesiumVectorData::GeoJsonFeature::properties
The properties field may contain any valid JSON object.
Definition at line 358 of file GeoJsonObjectTypes.h.
◆ style
std::optional<VectorStyle> CesiumVectorData::GeoJsonFeature::style = std::nullopt
Definition at line 379 of file GeoJsonObjectTypes.h.
◆ TYPE
GeoJsonObjectType CesiumVectorData::GeoJsonFeature::TYPE = GeoJsonObjectType::Feature
Definition at line 340 of file GeoJsonObjectTypes.h.
