CesiumVectorData::GeoJsonPoint Struct Reference
A Point geometry object. More...
glm::dvec3 coordinates
 The Cartographic coordinates for this Point.
std::optional< CesiumGeometry::AxisAlignedBox > boundingBox = std::nullopt
 The bounding box associated with this Point value, if any.
CesiumUtility::JsonValue::Object foreignMembers
 Any members specified on this object that are not part of the specification for this object.
std::optional< VectorStyle > style = std::nullopt
 The style to apply to this object as well as any child object. If not set, the style of any parent object or the default style will be used.
static constexpr GeoJsonObjectType TYPE = GeoJsonObjectType::Point
 The GeoJsonObjectType for a Point.
A Point value is a single cartographic position.
Definition at line 41 of file GeoJsonObjectTypes.h.
◆ boundingBox
std::optional<CesiumGeometry::AxisAlignedBox> CesiumVectorData::GeoJsonPoint::boundingBox = std::nullopt
Definition at line 53 of file GeoJsonObjectTypes.h.
◆ coordinates
glm::dvec3 CesiumVectorData::GeoJsonPoint::coordinates
Definition at line 48 of file GeoJsonObjectTypes.h.
◆ foreignMembers
CesiumUtility::JsonValue::Object CesiumVectorData::GeoJsonPoint::foreignMembers
Initial value:
std::map< std::string, JsonValue > Object
Definition JsonValue.h:73
Definition at line 62 of file GeoJsonObjectTypes.h.
◆ style
std::optional<VectorStyle> CesiumVectorData::GeoJsonPoint::style = std::nullopt
Definition at line 69 of file GeoJsonObjectTypes.h.
◆ TYPE
GeoJsonObjectType CesiumVectorData::GeoJsonPoint::TYPE = GeoJsonObjectType::Point
Definition at line 43 of file GeoJsonObjectTypes.h.
