CesiumVectorData::VectorRasterizer Class Reference
Rasterizes vector primitives into a CesiumImage::ImageAsset. More...
#include <CesiumVectorData/VectorRasterizer.h>
 VectorRasterizer (const CesiumGeospatial::GlobeRectangle &bounds, CesiumUtility::IntrusivePointer< CesiumImage::ImageAsset > &imageAsset, uint32_t mipLevel=0, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84)
 Creates a new VectorRasterizer representing the given rectangle on the globe.
void drawPolygon (const CesiumGeospatial::CartographicPolygon &polygon, const PolygonStyle &style)
 Draws a CesiumGeospatial::CartographicPolygon to the canvas.
void drawPolygon (const std::vector< std::vector< glm::dvec3 > > &polygon, const PolygonStyle &style)
 Draws a set of linear rings representing a polygon and its holes to the canvas.
void drawPolygon (const std::vector< std::vector< CesiumGeospatial::Cartographic > > &polygon, const PolygonStyle &style)
void drawPolyline (const std::vector< glm::dvec3 > &points, const LineStyle &style)
 Draws a polyline (a set of multiple line segments) to the canvas.
void drawPolyline (const std::vector< CesiumGeospatial::Cartographic > &points, const LineStyle &style)
void drawPoints (const std::vector< glm::dvec3 > &points, const PointStyle &style)
 Draws a set of points to the canvas.
void drawPoints (const std::vector< CesiumGeospatial::Cartographic > &points, const PointStyle &style)
void drawPoints (const std::vector< CesiumGeospatial::Cartographic > &points, const std::vector< const CesiumVectorData::PointStyle * > &styles)
void drawGeoJsonObject (const GeoJsonObject &geoJsonObject, const VectorStyle &style)
 Rasterizes a GeoJsonObject to the canvas.
void clear (const CesiumUtility::Color &clearColor)
 Fills the entire canvas with the given color.
CesiumUtility::IntrusivePointer< CesiumImage::ImageAsset > finalize ()
 Finalizes the rasterization operations, flushing all draw calls to the canvas, ensuring proper pixel ordering, and releasing the draw context.
Definition at line 30 of file VectorRasterizer.h.
◆ VectorRasterizer()
CesiumVectorData::VectorRasterizer::VectorRasterizer ( const CesiumGeospatial::GlobeRectangle & bounds,
CesiumUtility::IntrusivePointer< CesiumImage::ImageAsset > & imageAsset,
uint32_t mipLevel = 0,
boundsThe bounds on the globe that this rasterizer's canvas will cover.
imageAssetThe destination image asset. This CesiumImage::ImageAsset must be four channels, with only one byte per channel (RGBA32).
mipLevelThe mip level that the rasterizer should rasterize for the image.
ellipsoidThe ellipsoid to use.
◆ clear()
void CesiumVectorData::VectorRasterizer::clear ( const CesiumUtility::Color & clearColor)
clearColorThe color to use to clear the canvas.
◆ drawGeoJsonObject()
void CesiumVectorData::VectorRasterizer::drawGeoJsonObject ( const GeoJsonObject & geoJsonObject,
const VectorStyle & style )
This will recurse through any children of the GeoJsonObject as well. All GeoJSON objects will be considered (that is, no object's children will be ignored), but only LineString types (LineString and MultiLineString) and Polygon types (Polygon and MultiPolygon) will actually be rendered.
This method can potentially be very slow if a large tree is passed in. If better performance is needed, selecting a subset of leaf objects (those without any children) and calling drawGeoJsonObject on each one will have better results.
geoJsonObjectThe GeoJSON object to draw.
styleThe VectorStyle to use when drawing the object.
◆ drawPoints() [1/3]
void CesiumVectorData::VectorRasterizer::drawPoints ( const std::vector< CesiumGeospatial::Cartographic > & points,
const PointStyle & style )
pointsThe set of points to draw.
styleThe PointStyle to use when drawing the points.
◆ drawPoints() [2/3]
const std::vector< const CesiumVectorData::PointStyle * > & styles )
stylesThe PointStyle for each point to use when drawing.
Note
This method is intended for use with per-point styling, where each point may have a different style. The styles vector should be the same size as the points vector, and each point will be drawn using the corresponding style in the styles vector. If a style is nullptr, that point will not be drawn.
◆ drawPoints() [3/3]
void CesiumVectorData::VectorRasterizer::drawPoints ( const std::vector< glm::dvec3 > & points,
pointsThe set of points to draw. The coordinates should be specified in degrees.
◆ drawPolygon() [1/3]
void CesiumVectorData::VectorRasterizer::drawPolygon ( const CesiumGeospatial::CartographicPolygon & polygon,
const PolygonStyle & style )
polygonThe polygon to draw.
styleThe PolygonStyle to use when drawing the polygon.
◆ drawPolygon() [2/3]
void CesiumVectorData::VectorRasterizer::drawPolygon ( const std::vector< std::vector< CesiumGeospatial::Cartographic > > & polygon,
polygonThe polygon to draw. It is assumed to have right-hand winding order (exterior rings are counterclockwise, holes are clockwise) as is the case in GeoJSON. The coordinates should be specified in degrees.
◆ drawPolygon() [3/3]
void CesiumVectorData::VectorRasterizer::drawPolygon ( const std::vector< std::vector< glm::dvec3 > > & polygon,
◆ drawPolyline() [1/2]
void CesiumVectorData::VectorRasterizer::drawPolyline ( const std::vector< CesiumGeospatial::Cartographic > & points,
const LineStyle & style )
pointsThe set of points making up the polyline.
styleThe LineStyle to use when drawing the polyline.
◆ drawPolyline() [2/2]
void CesiumVectorData::VectorRasterizer::drawPolyline ( const std::vector< glm::dvec3 > & points,
pointsThe set of points making up the polyline. The coordinates should be specified in degrees.
◆ finalize()
CesiumUtility::IntrusivePointer< CesiumImage::ImageAsset > CesiumVectorData::VectorRasterizer::finalize ( )
Once a VectorRasterizer is finalized, it can no longer be used for drawing. Subsequent calls to its methods will do nothing.
