CesiumQuantizedMeshTerrain::LayerWriterResult Struct Reference
The result of writing a layer.json with LayerWriter::write. More...
#include <CesiumQuantizedMeshTerrain/LayerWriter.h>
std::vector< std::byte > bytes
 The final generated std::vector<std::byte> of the layer.json.
Definition at line 18 of file LayerWriter.h.
◆ bytes
std::vector<std::byte> CesiumQuantizedMeshTerrain::LayerWriterResult::bytes
Definition at line 22 of file LayerWriter.h.
◆ errors
std::vector<std::string> CesiumQuantizedMeshTerrain::LayerWriterResult::errors
Definition at line 27 of file LayerWriter.h.
◆ warnings
std::vector<std::string> CesiumQuantizedMeshTerrain::LayerWriterResult::warnings
Definition at line 32 of file LayerWriter.h.
