cesium-native 0.67.0
A RasterOverlay that obtains imagery data from the iTwin Cesium Curated Content API. More...
#include <CesiumRasterOverlays/ITwinCesiumCuratedContentRasterOverlay.h>
| ITwinCesiumCuratedContentRasterOverlay (const std::string &name, int64_t assetID, const std::string &iTwinAccessToken, const RasterOverlayOptions &overlayOptions={}) | |
| Creates a new instance. | |
Public Member Functions inherited from CesiumRasterOverlays::IonRasterOverlay | |
| IonRasterOverlay (const std::string &name, int64_t ionAssetID, const std::string &ionAccessToken, const RasterOverlayOptions &overlayOptions={}, const std::string &ionAssetEndpointUrl="https://api.cesium.com/") | |
| const std::optional< std::string > & | getAssetOptions () const noexcept |
Gets the additional options to be passed to the asset endpoint. | |
| void | setAssetOptions (const std::optional< std::string > &options) noexcept |
Sets the additional options to be passed to the asset endpoint. | |
| virtual CesiumAsync::Future< CreateTileProviderResult > | createTileProvider (const CreateRasterOverlayTileProviderParameters ¶meters) const override |
| Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Future. | |
Public Member Functions inherited from CesiumRasterOverlays::RasterOverlay | |
| RasterOverlay (const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions()) | |
| CesiumAsync::SharedFuture< void > & | getAsyncDestructionCompleteEvent (const CesiumAsync::AsyncSystem &asyncSystem) |
| A future that resolves when this RasterOverlay has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed. | |
| const std::string & | getName () const noexcept |
| Gets the name of this overlay. | |
| RasterOverlayOptions & | getOptions () noexcept |
| Gets options for this overlay. | |
| const RasterOverlayOptions & | getOptions () const noexcept |
| CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > | activate (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const |
| Activates this overlay. | |
| CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > | createPlaceholder (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const |
| Create a placeholder tile provider can be used in place of the real one while createTileProvider completes asynchronously. | |
Public Member Functions inherited from CesiumUtility::ReferenceCounted< T, false > | |
Public Types inherited from CesiumRasterOverlays::RasterOverlay | |
| using | CreateTileProviderResult |
| A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOverlayTileProvider, but may be a RasterOverlayLoadFailureDetails if creating the tile provider wasn't successful. | |
Protected Member Functions inherited from CesiumRasterOverlays::IonRasterOverlay | |
| IonRasterOverlay (const std::string &name, const std::string &overlayUrl, const std::string &ionAccessToken, bool needsAuthHeader, const RasterOverlayOptions &overlayOptions={}) | |
Definition at line 17 of file ITwinCesiumCuratedContentRasterOverlay.h.
| CesiumRasterOverlays::ITwinCesiumCuratedContentRasterOverlay::ITwinCesiumCuratedContentRasterOverlay | ( | const std::string & | name, |
| int64_t | assetID, | ||
| const std::string & | iTwinAccessToken, | ||
| const RasterOverlayOptions & | overlayOptions = {} ) |
The tiles that are provided by this instance will contain imagery data that was obtained from the iTwin CCC asset with the given ID, accessed with the given access token.
| name | The user-given name of this overlay layer. |
| assetID | The asset ID. |
| iTwinAccessToken | The access token. |
| overlayOptions | The RasterOverlayOptions for this instance. |
