CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler > Class Reference
Special case of ArrayJsonHandler for handling arrays of arbitrary JSON values. More...
#include <CesiumJsonReader/ArrayJsonHandler.h>
Inheritance diagram for CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >:
CesiumJsonReader::JsonHandler CesiumJsonReader::JsonHandler CesiumJsonReader::IJsonHandler CesiumJsonReader::IJsonHandler
Public Types
using ValueType = std::vector<CesiumUtility::JsonValue>
 The destination type.
using ValueType
void reset (IJsonHandler *pParent, std::vector< CesiumUtility::JsonValue > *pArray)
 Resets the parent and destination array of this ArrayJsonHandler.
virtual IJsonHandler * readObjectKey (const std::string_view &str) override
virtual IJsonHandler * readObjectEnd () override
 ArrayJsonHandler (Ts &&... args) noexcept
 Creates a new ArrayJsonHandler.
virtual IJsonHandler * readObjectKey (const std::string_view &str) noexcept override
virtual IJsonHandler * readObjectEnd () noexcept override
Additional Inherited Members
- Protected Member Functions inherited from CesiumJsonReader::JsonHandler
IJsonHandler * parent ()
IJsonHandler * ignoreAndReturnToParent ()
IJsonHandler * ignoreAndContinue ()
Definition at line 154 of file ArrayJsonHandler.h.
Member Typedef Documentation
◆ ValueType [1/2]
Definition at line 27 of file ArrayJsonHandler.h.
◆ ValueType [2/2]
Definition at line 159 of file ArrayJsonHandler.h.
◆ ArrayJsonHandler() [1/2]
Definition at line 161 of file ArrayJsonHandler.h.
◆ ArrayJsonHandler() [2/2]
CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::ArrayJsonHandler ( Ts &&... args)
inlinenoexcept
argsThe arguments that will be passed to the constructor of THandler when it's instantiated.
Definition at line 36 of file ArrayJsonHandler.h.
◆ readArrayEnd() [1/2]
A IJsonHandler that will handle the next read... call. This can be the same handler as the current one.
Reimplemented from CesiumJsonReader::JsonHandler.
Definition at line 113 of file ArrayJsonHandler.h.
◆ readArrayEnd() [2/2]
Definition at line 287 of file ArrayJsonHandler.h.
◆ readArrayStart() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readArrayStart ( )
inlineoverridevirtual
Definition at line 103 of file ArrayJsonHandler.h.
◆ readArrayStart() [2/2]
Definition at line 273 of file ArrayJsonHandler.h.
◆ readBool() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readBool ( bool b)
bThe boolean value.
Definition at line 57 of file ArrayJsonHandler.h.
◆ readBool() [2/2]
bThe boolean value.
Definition at line 184 of file ArrayJsonHandler.h.
◆ readDouble() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readDouble ( double d)
dThe double value.
Definition at line 77 of file ArrayJsonHandler.h.
◆ readDouble() [2/2]
dThe double value.
Definition at line 234 of file ArrayJsonHandler.h.
◆ readInt32() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readInt32 ( int32_t i)
iThe int32 value.
Definition at line 61 of file ArrayJsonHandler.h.
◆ readInt32() [2/2]
iThe int32 value.
Definition at line 194 of file ArrayJsonHandler.h.
◆ readInt64() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readInt64 ( int64_t i)
iThe int64 value.
Definition at line 69 of file ArrayJsonHandler.h.
◆ readInt64() [2/2]
iThe int64 value.
Definition at line 214 of file ArrayJsonHandler.h.
◆ readNull() [1/2]
Definition at line 53 of file ArrayJsonHandler.h.
◆ readNull() [2/2]
Definition at line 174 of file ArrayJsonHandler.h.
◆ readObjectEnd() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readObjectEnd ( )
inlineoverridevirtualnoexcept
Definition at line 101 of file ArrayJsonHandler.h.
◆ readObjectEnd() [2/2]
Definition at line 269 of file ArrayJsonHandler.h.
◆ readObjectKey() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readObjectKey ( const std::string_view & str)
strThe key.
Definition at line 96 of file ArrayJsonHandler.h.
◆ readObjectKey() [2/2]
strThe key.
Definition at line 265 of file ArrayJsonHandler.h.
◆ readObjectStart() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readObjectStart ( )
Definition at line 85 of file ArrayJsonHandler.h.
◆ readObjectStart() [2/2]
Definition at line 254 of file ArrayJsonHandler.h.
◆ readString() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readString ( const std::string_view & str)
strThe string value.
Definition at line 81 of file ArrayJsonHandler.h.
◆ readString() [2/2]
Definition at line 244 of file ArrayJsonHandler.h.
◆ readUint32() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readUint32 ( uint32_t i)
iThe uint32 value.
Definition at line 65 of file ArrayJsonHandler.h.
◆ readUint32() [2/2]
iThe uint32 value.
Definition at line 204 of file ArrayJsonHandler.h.
◆ readUint64() [1/2]
virtual IJsonHandler * CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::readUint64 ( uint64_t i)
iThe uint64 value.
Definition at line 73 of file ArrayJsonHandler.h.
◆ readUint64() [2/2]
iThe uint64 value.
Definition at line 224 of file ArrayJsonHandler.h.
◆ reportWarning() [1/2]
virtual void CesiumJsonReader::ArrayJsonHandler< CesiumUtility::JsonValue, JsonObjectJsonHandler >::reportWarning ( const std::string & warning,
std::vector< std::string > && context = std::vector<std::string>() )
warningThe warning to report.
contextContext information to include with this warning to help debugging.
Definition at line 115 of file ArrayJsonHandler.h.
◆ reportWarning() [2/2]
std::vector< std::string > && context = std::vector< std::string >() )
Definition at line 289 of file ArrayJsonHandler.h.
◆ reset() [1/2]
Definition at line 46 of file ArrayJsonHandler.h.
◆ reset() [2/2]
Definition at line 168 of file ArrayJsonHandler.h.
