Represents a string metadata property in EXT_structural_metadata. More...
#include <CesiumGltf/PropertyView.h>
| PropertyView () | |
| Constructs an empty property instance. | |
| PropertyView (const ClassProperty &classProperty) | |
| Constructs a property instance from a class definition only. | |
| PropertyViewStatusType | status () const noexcept |
| Constructs an empty property instance. false>status | |
| const std::optional< std::string > & | name () const noexcept |
| Constructs an empty property instance. false>name | |
| const std::optional< std::string > & | semantic () const noexcept |
| Constructs an empty property instance. false>semantic | |
| const std::optional< std::string > & | description () const noexcept |
| Constructs an empty property instance. false>description | |
| int64_t | arrayCount () const noexcept |
| Constructs an empty property instance. false>arrayCount | |
| bool | normalized () const noexcept |
| Constructs an empty property instance. false>normalized | |
| std::optional< std::string_view > | offset () const noexcept |
| Constructs an empty property instance. false>offset | |
| std::optional< std::string_view > | scale () const noexcept |
| Constructs an empty property instance. false>scale | |
| std::optional< std::string_view > | max () const noexcept |
| Constructs an empty property instance. false>max | |
| std::optional< std::string_view > | min () const noexcept |
| Constructs an empty property instance. false>min | |
| bool | required () const noexcept |
| Constructs an empty property instance. false>required | |
| std::optional< std::string_view > | noData () const noexcept |
| Constructs an empty property instance. false>noData | |
| std::optional< std::string_view > | defaultValue () const noexcept |
| Constructs an empty property instance. false>defaultValue | |
| PropertyType | propertyType () const noexcept |
| Returns the PropertyType of the property this view is accessing. | |
| PropertyView (PropertyViewStatusType status) | |
| Constructs an invalid instance for an erroneous property. | |
| PropertyView (const ClassProperty &classProperty, const PropertyTableProperty &, const CesiumGltf::Enum *) | |
| Constructs a property instance from a property table property and its class definition. | |
Protected Attributes | |
| PropertyViewStatusType | _status |
| Indicates the status of a property view. | |
Definition at line 1300 of file PropertyView.h.
Definition at line 1305 of file PropertyView.h.
Definition at line 1317 of file PropertyView.h.
inlineprotected |
| status | The value of PropertyViewStatus indicating the error with the property. |
Definition at line 1361 of file PropertyView.h.
inlineprotected |
Definition at line 1374 of file PropertyView.h.
inlinenoexcept |
false>arrayCount
Definition at line 1408 of file PropertyView.h.
inlinenoexcept |
false>defaultValue
Definition at line 1457 of file PropertyView.h.
inlinenoexcept |
false>description
Definition at line 1401 of file PropertyView.h.
inlinenoexcept |
false>max
Definition at line 1432 of file PropertyView.h.
inlinenoexcept |
false>min
Definition at line 1437 of file PropertyView.h.
inlinenoexcept |
false>name
Definition at line 1389 of file PropertyView.h.
inlinenoexcept |
false>noData
Definition at line 1447 of file PropertyView.h.
inlinenoexcept |
false>normalized
Definition at line 1413 of file PropertyView.h.
inlinenoexcept |
false>offset
Definition at line 1418 of file PropertyView.h.
inlinenoexcept |
Definition at line 1468 of file PropertyView.h.
inlinenoexcept |
false>required
Definition at line 1442 of file PropertyView.h.
inlinenoexcept |
false>scale
Definition at line 1425 of file PropertyView.h.
inlinenoexcept |
false>semantic
Definition at line 1394 of file PropertyView.h.
inlinenoexcept |
false>status
Definition at line 1384 of file PropertyView.h.
protected |
The PropertyView constructor always completes successfully. However, there may be fundamental errors with the property definition. In such cases, this enumeration provides the reason.
This is defined with a class of static consts as opposed to an enum, so that derived property view classes can extend the statuses with their own specific errors.
Definition at line 1472 of file PropertyView.h.
