Represents a boolean metadata property in EXT_structural_metadata. More...
#include <CesiumGltf/PropertyView.h>
| PropertyView () | |
| Constructs an empty property instance. | |
| PropertyView (const ClassProperty &classProperty) | |
| Constructs a property instance from a class definition only. | |
| PropertyViewStatusType | status () const noexcept |
| Constructs an empty property instance. false>status | |
| const std::optional< std::string > & | name () const noexcept |
| Constructs an empty property instance. false>name | |
| const std::optional< std::string > & | semantic () const noexcept |
| Constructs an empty property instance. false>semantic | |
| const std::optional< std::string > & | description () const noexcept |
| Constructs an empty property instance. false>description | |
| int64_t | arrayCount () const noexcept |
| Constructs an empty property instance. false>arrayCount | |
| bool | normalized () const noexcept |
| Constructs an empty property instance. false>normalized | |
| std::optional< bool > | offset () const noexcept |
| Constructs an empty property instance. false>offset | |
| std::optional< bool > | scale () const noexcept |
| Constructs an empty property instance. false>scale | |
| std::optional< bool > | max () const noexcept |
| Constructs an empty property instance. false>max | |
| std::optional< bool > | min () const noexcept |
| Constructs an empty property instance. false>min | |
| bool | required () const noexcept |
| Constructs an empty property instance. false>required | |
| std::optional< bool > | noData () const noexcept |
| Constructs an empty property instance. false>noData | |
| std::optional< bool > | defaultValue () const noexcept |
| Constructs an empty property instance. false>defaultValue | |
| PropertyType | propertyType () const noexcept |
| Returns the PropertyType of the property this view is accessing. | |
| PropertyView (PropertyViewStatusType status) | |
| Constructs an invalid instance for an erroneous property. | |
| PropertyView (const ClassProperty &classProperty, const PropertyTableProperty &, const CesiumGltf::Enum *) | |
| Constructs a property instance from a property table property and its class definition. | |
Protected Attributes | |
| PropertyViewStatusType | _status |
| Indicates the status of a property view. | |
Definition at line 1133 of file PropertyView.h.
Definition at line 1138 of file PropertyView.h.
Definition at line 1149 of file PropertyView.h.
inlineprotected |
| status | The value of PropertyViewStatus indicating the error with the property. |
Definition at line 1180 of file PropertyView.h.
inlineprotected |
Definition at line 1192 of file PropertyView.h.
inlinenoexcept |
false>arrayCount
Definition at line 1226 of file PropertyView.h.
inlinenoexcept |
false>defaultValue
Definition at line 1266 of file PropertyView.h.
inlinenoexcept |
false>description
Definition at line 1219 of file PropertyView.h.
inlinenoexcept |
false>max
Definition at line 1246 of file PropertyView.h.
inlinenoexcept |
false>min
Definition at line 1251 of file PropertyView.h.
inlinenoexcept |
false>name
Definition at line 1207 of file PropertyView.h.
inlinenoexcept |
false>noData
Definition at line 1261 of file PropertyView.h.
inlinenoexcept |
false>normalized
Definition at line 1231 of file PropertyView.h.
inlinenoexcept |
false>offset
Definition at line 1236 of file PropertyView.h.
inlinenoexcept |
Definition at line 1272 of file PropertyView.h.
inlinenoexcept |
false>required
Definition at line 1256 of file PropertyView.h.
inlinenoexcept |
false>scale
Definition at line 1241 of file PropertyView.h.
inlinenoexcept |
false>semantic
Definition at line 1212 of file PropertyView.h.
inlinenoexcept |
false>status
Definition at line 1202 of file PropertyView.h.
protected |
The PropertyView constructor always completes successfully. However, there may be fundamental errors with the property definition. In such cases, this enumeration provides the reason.
This is defined with a class of static consts as opposed to an enum, so that derived property view classes can extend the statuses with their own specific errors.
Definition at line 1276 of file PropertyView.h.
