CesiumGltf::AccessorWriter< T > Class Template Referencefinal
Provides write access to an AccessorView. More...
#include <CesiumGltf/AccessorWriter.h>
Public Types
typedef T value_type
 The type of the elements in the accessor.
 AccessorWriter (const AccessorView< T > &accessorView)
 Constructs a new instance from an AccessorView.
 AccessorWriter (std::byte *pData, int64_t stride, int64_t offset, int64_t size, bool normalized)
 Creates a new instance from low-level parameters.
 AccessorWriter (Model &model, const Accessor &accessor)
 Creates a new instance from a given model and Accessor.
 AccessorWriter (Model &model, int32_t accessorIndex) noexcept
 Creates a new instance from a given model and accessor index.
const T & operator[] (int64_t i) const
 Provides the specified accessor element.
int64_t size () const noexcept
 Returns the size (number of elements) of this accessor.
bool normalized () const noexcept
 Returns whether the accessor values are normalized.
AccessorViewStatus status () const noexcept
 Gets the status of this accessor writer.
int64_t stride () const noexcept
 Returns the stride of this accessor, which is the number of bytes from the start of one element to the start of the next.
int64_t offset () const noexcept
 Returns the offset of this accessor, which is the number of bytes from the start of the buffer to the first element.
std::byte * data () noexcept
 Returns a pointer to the first byte of this accessor view's data. The elements are stored contiguously, so the next one starts stride bytes later.
template<class T>
class CesiumGltf::AccessorWriter< T >
Definition at line 10 of file AccessorWriter.h.
Member Typedef Documentation
◆ value_type
template<class T>
typedef T CesiumGltf::AccessorWriter< T >::value_type
Definition at line 18 of file AccessorWriter.h.
◆ AccessorWriter() [1/5]
template<class T>
CesiumGltf::AccessorWriter< T >::AccessorWriter ( )
Definition at line 20 of file AccessorWriter.h.
◆ AccessorWriter() [2/5]
template<class T>
CesiumGltf::AccessorWriter< T >::AccessorWriter ( const AccessorView< T > & accessorView)
Definition at line 25 of file AccessorWriter.h.
◆ AccessorWriter() [3/5]
template<class T>
CesiumGltf::AccessorWriter< T >::AccessorWriter ( std::byte * pData,
int64_t stride,
int64_t offset,
int64_t size,
bool normalized )
The provided parameters are not validated in any way, and so this overload can easily be used to access invalid memory.
pDataThe raw data buffer from which to read.
strideThe stride, in bytes, between successive elements.
offsetThe offset from the start of the buffer to the first element.
sizeThe total number of elements.
normalizedWhether the accessor values are normalized.
Definition at line 30 of file AccessorWriter.h.
◆ AccessorWriter() [4/5]
template<class T>
CesiumGltf::AccessorWriter< T >::AccessorWriter ( Model & model,
const Accessor & accessor )
If the accessor cannot be viewed, the construct will still complete successfully without throwing an exception. However, size will return 0 and status will indicate what went wrong.
modelThe model to access.
accessorThe accessor to view.
Definition at line 39 of file AccessorWriter.h.
◆ AccessorWriter() [5/5]
template<class T>
int32_t accessorIndex )
inlinenoexcept
accessorIndexThe index of the accessor to view in the model's Model::accessors list.
Definition at line 43 of file AccessorWriter.h.
◆ data()
template<class T>
std::byte * CesiumGltf::AccessorWriter< T >::data ( )
inlinenoexcept
The start of this view.
Definition at line 75 of file AccessorWriter.h.
◆ normalized()
template<class T>
bool CesiumGltf::AccessorWriter< T >::normalized ( ) const
inlinenoexcept
Definition at line 56 of file AccessorWriter.h.
◆ offset()
template<class T>
int64_t CesiumGltf::AccessorWriter< T >::offset ( ) const
inlinenoexcept
The offset.
Definition at line 72 of file AccessorWriter.h.
◆ operator[]() [1/2]
template<class T>
T & CesiumGltf::AccessorWriter< T >::operator[] ( int64_t i)
iThe index of the element.
The constant reference to the accessor element.
Exceptions
Astd::range_error if the given index is negative or not smaller than the size of this accessor.
Definition at line 50 of file AccessorWriter.h.
◆ operator[]() [2/2]
template<class T>
const T & CesiumGltf::AccessorWriter< T >::operator[] ( int64_t i) const
Exceptions
Definition at line 47 of file AccessorWriter.h.
◆ size()
template<class T>
int64_t CesiumGltf::AccessorWriter< T >::size ( ) const
inlinenoexcept
This is the number of elements of type T that this accessor contains.
The size.
Definition at line 53 of file AccessorWriter.h.
◆ status()
template<class T>
AccessorViewStatus CesiumGltf::AccessorWriter< T >::status ( ) const
inlinenoexcept
Indicates whether the writer accurately reflects the accessor's data, or whether an error occurred.
Definition at line 64 of file AccessorWriter.h.
◆ stride()
template<class T>
int64_t CesiumGltf::AccessorWriter< T >::stride ( ) const
inlinenoexcept
The stride.
Definition at line 69 of file AccessorWriter.h.
