CesiumGltf::AccessorView< T > Class Template Referencefinal
A view on the data of one accessor of a glTF asset. More...
#include <CesiumGltf/AccessorView.h>
Public Types
typedef T value_type
 The type of the elements in the accessor.
 AccessorView (AccessorViewStatus status=AccessorViewStatus::InvalidAccessorIndex)
 Construct a new instance not pointing to any data.
 AccessorView (const std::byte *pData, int64_t stride, int64_t offset, int64_t size, bool normalized)
 Creates a new instance from low-level parameters.
 AccessorView (const Model &model, const Accessor &accessor) noexcept
 Creates a new instance from a given model and Accessor.
 AccessorView (const Model &model, int32_t accessorIndex) noexcept
 Creates a new instance from a given model and accessor index.
const T & operator[] (int64_t i) const
 Provides the specified accessor element.
int64_t size () const noexcept
 Returns the size (number of elements) of this accessor.
AccessorViewStatus status () const noexcept
 Gets the status of this accessor view.
int64_t stride () const noexcept
 Returns the stride of this accessor, which is the number of bytes from the start of one element to the start of the next.
int64_t offset () const noexcept
 Returns the offset of this accessor, which is the number of bytes from the start of the buffer to the first element.
bool normalized () const noexcept
 Returns whether the accessor values are normalized.
const std::byte * data () const noexcept
 Returns a pointer to the first byte of this accessor view's data. The elements are stored contiguously, so the next one starts stride bytes later.
template<class T>
class CesiumGltf::AccessorView< T >
It provides the actual accessor data like an array of elements. The type of the accessor elements is determined by the template parameter. Instances are usually from an Accessor, and the operator[]() can be used to access the elements:
Model model = anyOldFunctionToGetAModel();
AccessorView<glm::vec3> positions(model, 0);
glm::vec3 firstPosition = positions[0];
Template Parameters
TThe type of the elements in the accessor.
Definition at line 87 of file AccessorView.h.
Member Typedef Documentation
◆ value_type
template<class T>
typedef T CesiumGltf::AccessorView< T >::value_type
Definition at line 100 of file AccessorView.h.
◆ AccessorView() [1/4]
template<class T>
CesiumGltf::AccessorView< T >::AccessorView ( AccessorViewStatus status = AccessorViewStatus::InvalidAccessorIndex)
The new instance will have a size of 0 and a status of AccessorViewStatus::InvalidAccessorIndex.
statusThe status of the new accessor. Defaults to AccessorViewStatus::InvalidAccessorIndex.
Definition at line 111 of file AccessorView.h.
◆ AccessorView() [2/4]
template<class T>
CesiumGltf::AccessorView< T >::AccessorView ( const std::byte * pData,
int64_t stride,
int64_t offset,
int64_t size,
bool normalized )
The provided parameters are not validated in any way, and so this overload can easily be used to access invalid memory.
pDataThe raw data buffer from which to read.
strideThe stride, in bytes, between successive elements.
offsetThe offset from the start of the buffer to the first element.
sizeThe total number of elements.
normalizedWhether the accessor values are normalized.
Definition at line 132 of file AccessorView.h.
◆ AccessorView() [3/4]
template<class T>
CesiumGltf::AccessorView< T >::AccessorView ( const Model & model,
const Accessor & accessor )
inlinenoexcept
If the accessor cannot be viewed, the construct will still complete successfully without throwing an exception. However, size will return 0 and status will indicate what went wrong.
modelThe model to access.
accessorThe accessor to view.
Definition at line 156 of file AccessorView.h.
◆ AccessorView() [4/4]
template<class T>
int32_t accessorIndex )
inlinenoexcept
accessorIndexThe index of the accessor to view in the model's Model::accessors list.
Definition at line 173 of file AccessorView.h.
◆ data()
template<class T>
const std::byte * CesiumGltf::AccessorView< T >::data ( ) const
inlinenoexcept
The start of this view.
Definition at line 248 of file AccessorView.h.
◆ normalized()
template<class T>
bool CesiumGltf::AccessorView< T >::normalized ( ) const
inlinenoexcept
Definition at line 239 of file AccessorView.h.
◆ offset()
template<class T>
int64_t CesiumGltf::AccessorView< T >::offset ( ) const
inlinenoexcept
The offset.
Definition at line 232 of file AccessorView.h.
◆ operator[]()
template<class T>
const T & CesiumGltf::AccessorView< T >::operator[] ( int64_t i) const
iThe index of the element.
The constant reference to the accessor element.
Exceptions
Astd::range_error if the given index is negative or not smaller than the size of this accessor.
Definition at line 192 of file AccessorView.h.
◆ size()
template<class T>
int64_t CesiumGltf::AccessorView< T >::size ( ) const
inlinenoexcept
This is the number of elements of type T that this accessor contains.
The size.
Definition at line 208 of file AccessorView.h.
◆ status()
template<class T>
AccessorViewStatus CesiumGltf::AccessorView< T >::status ( ) const
inlinenoexcept
Indicates whether the view accurately reflects the accessor's data, or whether an error occurred.
Definition at line 216 of file AccessorView.h.
◆ stride()
template<class T>
int64_t CesiumGltf::AccessorView< T >::stride ( ) const
inlinenoexcept
The stride.
Definition at line 224 of file AccessorView.h.
