AccessorWriter.h
3#include <CesiumGltf/AccessorView.h>
5namespace CesiumGltf {
6
10template <class T> class AccessorWriter final {
11private:
12 AccessorView<T> _accessor;
13
14public:
18 typedef T value_type;
19
20 AccessorWriter() : _accessor() {}
21
25 AccessorWriter(const AccessorView<T>& accessorView)
26 : _accessor(accessorView) {}
27
31 std::byte* pData,
32 int64_t stride,
33 int64_t offset,
34 int64_t size,
35 bool normalized)
36 : _accessor(pData, stride, offset, size, normalized) {}
37
39 AccessorWriter(Model& model, const Accessor& accessor)
40 : _accessor(model, accessor) {}
41
43 AccessorWriter(Model& model, int32_t accessorIndex) noexcept
44 : _accessor(model, accessorIndex) {}
45
47 const T& operator[](int64_t i) const { return this->_accessor[i]; }
48
50 T& operator[](int64_t i) { return const_cast<T&>(this->_accessor[i]); }
51
53 int64_t size() const noexcept { return this->_accessor.size(); }
54
56 bool normalized() const noexcept { return this->_accessor->normalized(); }
57
64 AccessorViewStatus status() const noexcept {
65 return this->_accessor.status();
66 }
67
69 int64_t stride() const noexcept { return this->_accessor.stride(); }
70
72 int64_t offset() const noexcept { return this->_accessor.offset(); }
73
75 std::byte* data() noexcept {
76 return const_cast<std::byte*>(this->_accessor.data());
77 }
78};
79
80} // namespace CesiumGltf
A view on the data of one accessor of a glTF asset.
Returns whether the accessor values are normalized.
Returns the offset of this accessor, which is the number of bytes from the start of the buffer to the...
Returns the stride of this accessor, which is the number of bytes from the start of one element to th...
Returns the size (number of elements) of this accessor.
const std::byte * data() const noexcept
Returns a pointer to the first byte of this accessor view's data. The elements are stored contiguousl...
Gets the status of this accessor view.
std::byte * data() noexcept
T & operator[](int64_t i)
Provides the specified accessor element.
AccessorWriter(Model &model, const Accessor &accessor)
Creates a new instance from a given model and Accessor.
AccessorWriter(std::byte *pData, int64_t stride, int64_t offset, int64_t size, bool normalized)
Creates a new instance from low-level parameters.
T value_type
The type of the elements in the accessor.
AccessorWriter(Model &model, int32_t accessorIndex) noexcept
Creates a new instance from a given model and accessor index.
AccessorWriter(const AccessorView< T > &accessorView)
Constructs a new instance from an AccessorView.
const T & operator[](int64_t i) const
Gets the status of this accessor writer.
AccessorViewStatus
Indicates the status of an accessor view.
This class is not meant to be instantiated directly. Use Accessor instead.
Definition Accessor.h:12
Definition Model.h:14
