TilesetMetadata.h
3#include <Cesium3DTiles/Asset.h>
4#include <Cesium3DTiles/GroupMetadata.h>
5#include <Cesium3DTiles/Properties.h>
6#include <Cesium3DTiles/Schema.h>
7#include <Cesium3DTiles/Statistics.h>
8#include <Cesium3DTilesSelection/Library.h>
9#include <CesiumAsync/SharedFuture.h>
10#include <CesiumUtility/ExtensibleObject.h>
11
12#include <optional>
13#include <string>
14#include <unordered_map>
15#include <vector>
16
17namespace CesiumAsync {
18class AsyncSystem;
19class IAssetAccessor;
20} // namespace CesiumAsync
21
22namespace Cesium3DTilesSelection {
23
29class CESIUM3DTILESSELECTION_API TilesetMetadata
31public:
32 ~TilesetMetadata() noexcept;
33
38
42 std::unordered_map<std::string, Cesium3DTiles::Properties> properties;
43
48 std::optional<Cesium3DTiles::Schema> schema;
49
54 std::optional<std::string> schemaUri;
55
59 std::optional<Cesium3DTiles::Statistics> statistics;
60
66 std::vector<Cesium3DTiles::GroupMetadata> groups;
67
71 std::optional<Cesium3DTiles::MetadataEntity> metadata;
72
78 std::optional<double> geometricError;
79
83 std::vector<std::string> extensionsUsed;
84
89 std::vector<std::string> extensionsRequired;
90
107 const CesiumAsync::AsyncSystem& asyncSystem,
108 const std::shared_ptr<CesiumAsync::IAssetAccessor>& pAssetAccessor);
109
110private:
111 std::optional<CesiumAsync::SharedFuture<void>> _loadingFuture;
112 std::optional<std::string> _loadingSchemaUri;
113 std::shared_ptr<bool> _pLoadingCanceled;
114};
115
116} // namespace Cesium3DTilesSelection
Holds the metadata associated with a Tileset or an external tileset. This holds all of the fields of ...
CesiumAsync::SharedFuture< void > & loadSchemaUri(const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor)
Asynchronously loads the schema from the schemaUri. If the schemaUri does not contain a value,...
std::vector< Cesium3DTiles::GroupMetadata > groups
An array of groups that tile content may belong to. Each element of this array is a metadata entity t...
std::optional< Cesium3DTiles::Schema > schema
An object defining the structure of metadata classes and enums. When this is defined,...
std::vector< std::string > extensionsRequired
Names of 3D Tiles extensions required to properly load this tileset. Each element of this array shall...
std::optional< Cesium3DTiles::Statistics > statistics
An object containing statistics about metadata entities.
std::optional< double > geometricError
The error, in meters, introduced if this tileset is not rendered. At runtime, the geometric error is ...
std::optional< Cesium3DTiles::MetadataEntity > metadata
A metadata entity that is associated with this tileset.
std::vector< std::string > extensionsUsed
Names of 3D Tiles extensions used somewhere in this tileset.
std::unordered_map< std::string, Cesium3DTiles::Properties > properties
A dictionary object of metadata about per-feature properties.
Cesium3DTiles::Asset asset
std::optional< std::string > schemaUri
The URI (or IRI) of the external schema file. When this is defined, then schema shall be undefined.
A system for managing asynchronous requests and tasks.
Definition AsyncSystem.h:37
Provides asynchronous access to assets, usually files downloaded via HTTP.
A value that will be available in the future, as produced by AsyncSystem. Unlike Future,...
Classes that support asynchronous operations.
Definition Asset.h:15
