GoogleMapTilesRasterOverlay.h
3#include <CesiumRasterOverlays/Library.h>
4#include <CesiumRasterOverlays/RasterOverlay.h>
5#include <CesiumUtility/JsonValue.h>
6
7#include <optional>
8#include <string>
9
10namespace CesiumRasterOverlays {
11
19 std::string key;
20
24 std::string session;
25
33 std::string expiry;
34
38 uint32_t tileWidth;
39
43 uint32_t tileHeight;
44
49 std::string imageFormat;
50
58 bool showLogo = true;
59
63 std::string apiBaseUrl{"https://tile.googleapis.com/"};
64};
65
73 inline static const std::string roadmap = "roadmap";
74
78 inline static const std::string satellite = "satellite";
79
85 inline static const std::string terrain = "terrain";
86
91 inline static const std::string streetview = "streetview";
92};
93
104 inline static const std::string layerRoadmap = "layerRoadmap";
105
110 inline static const std::string layerStreetview = "layerStreetview";
111
115 inline static const std::string layerTraffic = "layerTraffic";
116};
117
126 inline static const std::string png = "png";
127
132 inline static const std::string jpeg = "jpeg";
133};
134
142 inline static const std::string scaleFactor1x = "scaleFactor1x";
143
147 inline static const std::string scaleFactor2x = "scaleFactor2x";
148
152 inline static const std::string scaleFactor4x = "scaleFactor4x";
153};
154
162 std::string key;
163
168 std::string mapType{"satellite"};
169
176 std::string language{"en-US"};
177
183 std::string region{"US"};
184
192 std::optional<std::string> imageFormat{};
193
202 std::optional<std::string> scale{};
203
219 std::optional<bool> highDpi{};
220
225 std::optional<std::vector<std::string>> layerTypes{};
226
237 std::optional<CesiumUtility::JsonValue::Array> styles{};
238
246 std::optional<bool> overlay{};
247
251 std::string apiBaseUrl{"https://tile.googleapis.com/"};
252};
253
258class CESIUMRASTEROVERLAYS_API GoogleMapTilesRasterOverlay
259 : public RasterOverlay {
260public:
270 const std::string& name,
271 const GoogleMapTilesNewSessionParameters& newSessionParameters,
272 const RasterOverlayOptions& overlayOptions = {});
273
283 const std::string& name,
284 const GoogleMapTilesExistingSession& existingSession,
285 const RasterOverlayOptions& overlayOptions = {});
286
290 const override;
291
292private:
294 const CreateRasterOverlayTileProviderParameters& parameters) const;
295
296 std::optional<GoogleMapTilesNewSessionParameters> _newSessionParameters;
297 std::optional<GoogleMapTilesExistingSession> _existingSession;
298};
299
300} // namespace CesiumRasterOverlays
Definition Future.h:29
virtual CesiumAsync::Future< CreateTileProviderResult > createTileProvider(const CreateRasterOverlayTileProviderParameters &parameters) const override
GoogleMapTilesRasterOverlay(const std::string &name, const GoogleMapTilesNewSessionParameters &newSessionParameters, const RasterOverlayOptions &overlayOptions={})
Constructs a new overlay that will start a new Google Maps Tiles session with the specified parameter...
GoogleMapTilesRasterOverlay(const std::string &name, const GoogleMapTilesExistingSession &existingSession, const RasterOverlayOptions &overlayOptions={})
Constructs a new overlay that will use an existing Google Maps Tiles session that was previously star...
RasterOverlay(const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions())
Creates a new instance.
Classes for raster overlays, which allow draping massive 2D textures over a model.
Holds the parameters for an existing Google Maps Tiles session.
uint32_t tileHeight
The height of the tiles measured in pixels.
std::string session
The session token value to include in all Map Tiles API requests.
std::string expiry
A string that contains the time (in seconds since the epoch) at which the token expires.
std::string key
The Google Map Tiles API key to use.
The base URL for the Google Maps Tiles API.
The image format, which can be either GoogleMapTilesImageFormat::png or GoogleMapTilesImageFormat::jp...
uint32_t tileWidth
The width of the tiles measured in pixels.
bool showLogo
Whether or not the GoogleMapTilesRasterOverlay should show the Google Maps logo.
Standard values for GoogleMapTilesNewSessionParameters::imageFormat.
Joint Photographic Experts Group format. This format doesn't support transparency.
Portable Network Graphics format. This format supports transparency.
Standard values for GoogleMapTilesNewSessionParameters::layerTypes.
Required if you specify terrain as the map type. Can also be optionally overlaid on the satellite map...
Shows Street View-enabled streets and locations using blue outlines on the map.
Displays current traffic conditions.
Standard values for GoogleMapTilesNewSessionParameters::mapType.
The standard Google Maps painted map tiles.
Street View panoramas. This is a documented map type supported by the service, but it is unlikely to ...
Satellite imagery.
Terrain imagery. When selecting terrain as the map type, you must also set the GoogleMapTilesNewSessi...
Holds the parameters for starting a new Google Maps Tiles session.
std::optional< std::string > imageFormat
Specifies the file format to return. See GoogleMapTilesImageFormat for standard values.
std::optional< CesiumUtility::JsonValue::Array > styles
An array of JSON style objects that specify the appearance and detail level of map features such as r...
std::string region
A Common Locale Data Repository region identifier (two uppercase letters) that represents the physica...
std::optional< std::vector< std::string > > layerTypes
An array of values that specifies the layer types added to the map. See GoogleMapTilesLayerType for s...
std::optional< bool > highDpi
Specifies whether to return high-resolution tiles.
std::optional< bool > overlay
A boolean value that specifies whether layerTypes should be rendered as a separate overlay,...
std::optional< std::string > scale
Scales-up the size of map elements (such as road labels), while retaining the tile size and coverage ...
An IETF language tag that specifies the language used to display information on the tiles....
std::string mapType
The type of base map. See GoogleMapTilesMapType for standard values.
Standard values for GoogleMapTilesNewSessionParameters::scale.
Doubles label size and removes minor feature labels.
The default.
Quadruples label size and removes minor feature labels.
Options for loading raster overlays.
