CesiumRasterOverlays::GoogleMapTilesExistingSession Struct Reference
Holds the parameters for an existing Google Maps Tiles session. More...
#include <CesiumRasterOverlays/GoogleMapTilesRasterOverlay.h>
std::string key
 The Google Map Tiles API key to use.
std::string session
 The session token value to include in all Map Tiles API requests.
std::string expiry
 A string that contains the time (in seconds since the epoch) at which the token expires.
uint32_t tileWidth
 The width of the tiles measured in pixels.
uint32_t tileHeight
 The height of the tiles measured in pixels.
std::string imageFormat
 The image format, which can be either GoogleMapTilesImageFormat::png or GoogleMapTilesImageFormat::jpeg.
bool showLogo = true
 Whether or not the GoogleMapTilesRasterOverlay should show the Google Maps logo.
std::string apiBaseUrl {"https://tile.googleapis.com/"}
 The base URL for the Google Maps Tiles API.
Definition at line 15 of file GoogleMapTilesRasterOverlay.h.
◆ apiBaseUrl
std::string CesiumRasterOverlays::GoogleMapTilesExistingSession::apiBaseUrl {"https://tile.googleapis.com/"}
Definition at line 63 of file GoogleMapTilesRasterOverlay.h.
◆ expiry
std::string CesiumRasterOverlays::GoogleMapTilesExistingSession::expiry
Google documents that a session token is valid for two weeks from its creation time, but that this policy might change without notice.
Definition at line 33 of file GoogleMapTilesRasterOverlay.h.
◆ imageFormat
std::string CesiumRasterOverlays::GoogleMapTilesExistingSession::imageFormat
Definition at line 49 of file GoogleMapTilesRasterOverlay.h.
◆ key
std::string CesiumRasterOverlays::GoogleMapTilesExistingSession::key
Definition at line 19 of file GoogleMapTilesRasterOverlay.h.
◆ session
std::string CesiumRasterOverlays::GoogleMapTilesExistingSession::session
Definition at line 24 of file GoogleMapTilesRasterOverlay.h.
◆ showLogo
bool CesiumRasterOverlays::GoogleMapTilesExistingSession::showLogo = true
Google requires the logo to be shown, so setting this to false is only valid when something else is already showing the logo.
Definition at line 58 of file GoogleMapTilesRasterOverlay.h.
◆ tileHeight
uint32_t CesiumRasterOverlays::GoogleMapTilesExistingSession::tileHeight
Definition at line 43 of file GoogleMapTilesRasterOverlay.h.
◆ tileWidth
uint32_t CesiumRasterOverlays::GoogleMapTilesExistingSession::tileWidth
Definition at line 38 of file GoogleMapTilesRasterOverlay.h.
