CesiumRasterOverlays::GoogleMapTilesLayerType Struct Reference
Standard values for GoogleMapTilesNewSessionParameters::layerTypes. More...
#include <CesiumRasterOverlays/GoogleMapTilesRasterOverlay.h>
static const std::string layerRoadmap = "layerRoadmap"
 Required if you specify terrain as the map type. Can also be optionally overlaid on the satellite map type. Has no effect on roadmap tiles.
static const std::string layerStreetview = "layerStreetview"
 Shows Street View-enabled streets and locations using blue outlines on the map.
static const std::string layerTraffic = "layerTraffic"
 Displays current traffic conditions.
Definition at line 98 of file GoogleMapTilesRasterOverlay.h.
◆ layerRoadmap
const std::string CesiumRasterOverlays::GoogleMapTilesLayerType::layerRoadmap = "layerRoadmap"
inlinestatic
Definition at line 104 of file GoogleMapTilesRasterOverlay.h.
◆ layerStreetview
const std::string CesiumRasterOverlays::GoogleMapTilesLayerType::layerStreetview = "layerStreetview"
inlinestatic
Definition at line 110 of file GoogleMapTilesRasterOverlay.h.
◆ layerTraffic
const std::string CesiumRasterOverlays::GoogleMapTilesLayerType::layerTraffic = "layerTraffic"
inlinestatic
Definition at line 115 of file GoogleMapTilesRasterOverlay.h.
