Cesium for Unreal 2.13.2
Cesium strives to maintain a high standard for code quality across all of its codebases. The effort to write readable, organized, and consistent code makes it much easier for contributors to work with the code, whether new or experienced.
That said, the Cesium for Unreal plugin is a bit special. It combines code from Cesium Native and Unreal Engine, two large codebases with diverging guidelines, libraries, and design decisions. This guide attempts to reconcile between these two codebases and make recommendations where there are conflicts.
Before diving into this guide, we recommend the following:
This guide will explicitly link to sections in the above resources when relevant, but it is good practice to learn the overall expectations of both environments.
IN GENERAL, if you're writing code for a public API, defer to Unreal Engine's style and code standards. When working with private APIs or implementation details, fall back on Cesium Native's C++ style. Use existing, similar code to infer the appropriate style for your own.
First, check out the Naming Conventions section in the Unreal Engine coding standard. Then, read below.
F
or actor subclasses with A
. If these prefixes are absent, the Unreal Header Tool will likely complain during the build process, and subsequently fail to compile your code.ACesium3DTileset
is defined in Cesium3DTileset.h
and implemented in Cesium3DTileset.cpp
, and not ACesium3DTileset.h
or ACesium3DTileset.cpp
.struct
or class
in the public API should be prefaced with the word "Cesium". This helps to clearly separate our API from other elements in Unreal, and allows users to more easily search for our components in Unreal.Note that the above is not enforced for classes that are used in private implementations. For example, users won't ever interact directly with
LoadModelResult
orUnrealAssetAccessor
, so these do not include a "Cesium" prefix.We also tend to omit "Cesium" from the names of
enum
s, for readability. Just be sure to add Documentation so users understand how it is used in Cesium.
Functions and fields in the public API should be written in PascalCase
. However, continue to use lowerCamelCase
for any private members or anonymous namespace functions.
For pointer variables that are mentioned in the public API, e.g., public fields or function parameters, omit the p
prefix. However, continue to use p
to prefix pointers in private code.
If you're wondering about CESIUMRUNTIME_API
, this macro is necessary for all public types in our plugin (and free functions, if we have any) to be DLL-exported. Otherwise, they won't be usable by other modules on Windows. Make sure to include this macro in the public
class, struct, or function definition. (If you're working in the Editor module, use CESIUMEDITOR_API
instead.)
Aim to assign names to variables, functions, etc. that are succinctly descriptive. This is crucial for creating an intuitive user experience with the public API, but even private code should aspire to this standard.
When in doubt, err on the side of being overly explicit. Try to be precise about scope and meaning.
For example, consider the context of multiple frames of reference in Cesium for Unreal. The plugin has to operate in multiple coordinate systems: Unreal's coordinate system, Earth-Centered Earth-Fixed coordinates, and cartographic coordinates (longitude, latitude, height). Whenever something deals with position or orientation, it is important to distinguish what space it is operating in.
This intentionally vague example leaves a lot to be desired:
From a glance, it is not clear what the intended frame-of-reference is. (Maybe you assumed it was in Unreal space due to Location
, but what is Transform
for?) The function body might give us a hint, but the declaration could use more clarity. Adding documentation will definitely help here, and in some cases that is enough to avoid ambiguity.
However, we can take this even a step further. Let's rename the function and its parameter so that the intent is very obvious from the start.
In the same vein, avoid abbreviations unless they are commonly accepted or used across the codebase. This improves readability such that code is understandable to new developers from a glance. (Additionally, consider developers for whom English is not their first language; the arbitrary abbreviations can be even more confusing.)
We also write out "Earth-Centered, Earth-Fixed" and "Longitude, Latitude, Height" in the plugin. Though this makes for longer names, it is helpful for users who are new to geospatial and aren't familiar with abbreviations like ECEF. However, we still use WGS84 because the full name is cumbersome, and less helpful when spelled out.
Units should stay consistent across the API to avoid confusion as values are passed. In particular:
It's encouraged to leave documentation about the expected units and/or frame of reference for a function and its parameters. This comment in CesiumGeoreference.h
is a good example:
Unreal provides engine-specific pointer types that may not be obvious to distinguish from one another. This community guide goes into detail about the differences between these types, but they are summarized for convenience below.
Type | Description |
TObjectPtr | An optional replacement for raw pointers. The type T should be complete and derived from UObject . |
TSoftObjectPtr | Used in UProperties. |
TWeakObjectPtr | Used to reference already instantiated objects. Will resolve to null if the object gets destroyed or garbage collected. |
Generally, the above pointers are used whenever you instantiate something that inherits from an Unreal type (e.g., UObject
, USceneComponent
). Of course, raw pointers may be used where ownership is not required.
Unreal also provides TUniquePtr
and TSharedPtr
definitions, equivalent to their std
counterparts. For consistency, Cesium for Unreal prefers using TUniquePtr
and TSharedPtr
. However, you can't use these when the type T
is a UObject
, as UObject
s are always garbage collected.
Unreal contains various vector and matrix classes that are functionally similar to the classes in glm
, e.g., FVector
for glm::dvec3
, FMatrix
for glm::dmat4
However, if you ever find yourself doing any vector and matrix arithmetic, it is strongly encouraged to do operations with glm
first. The computed result can later be copied into the corresponding Unreal Engine type.
This is especially recommended for matrix math. FMatrix
makes strong assumptions about the content of the matrix that can result in unexpected behaviors. It also defines operators in ways that deviate from typical linear algebra expectations. If you need the result to be an FMatrix
, first use glm::dmat4
for the computation, and then copy it into an FMatrix
Example of faulty
FMatrix
math:The
FMatrix::operator*
composed matrices in the opposite of the normal order. If you wanted a matrix that transforms byA
then byB
, Unreal would want you to multiplyA * B
. You would otherwise multiplyB * A
inglm
Documentation is generated by Doxygen before being published online. Therefore, any public API should be documented with Doxygen-compatible comments that follow the standards put forth by Cesium Native.
The sole exception is to avoid the use of @copydoc
for UPROPERTY
s or UFUNCTION
s in Cesium for Unreal. Unreal Engine uses comments to generate tooltips for object properties and Blueprints functions, but it won't parse every Doxygen command. Often, the tooltip often copies the text of a comment verbatim. While this isn't an issue for most comments, @copydoc
will never create a copy of the target comment, so the tooltip will be left as "@copydoc"
We circumvent the above by manually duplicating the documentation comments as necessary. But feel free to use @copydoc
when documenting elements that are only used in C++.
Cesium for Unreal's source code (located in the Source
folder) is divided into Runtime
and Editor
. The Editor
folder contains elements that are used within the Unreal Editor only, e.g., UI components or functionality. These will not be included in a packaged build, so don't place anything here that is otherwise required for the application to run!
The Runtime
folder contains everything else. The classes in here may be acted upon by the Unreal Editor, but they are not exclusive to the Editor.
Within the Runtime
folder are two subfolders: Public
and Private
Public
folder should contain files related to the public API.Private
folder contains everything else: private classes, functions, etc. that users will never have to deal with.Be aware that the Private
folder can reference files in the Public
folder, but not vice versa. It's possible that a class in Public
needs to #include
something that would otherwise exist in the Private
folder, e.g., the type of a private member variable. Use forward declarations to avoid this where possible, but you ultimately may have to move that class to the Public
folder, even if it's not public API. This is fine.
