UCesiumAzureMapsRasterOverlay Class Reference
A raster overlay that directly accesses Azure Maps. More...
#include <CesiumAzureMapsRasterOverlay.h>
Inheritance diagram for UCesiumAzureMapsRasterOverlay:
UCesiumRasterOverlay
FString Key
 The Azure Maps subscription key to use.
FString ApiVersion = "2024-04-01"
 The version number of Azure Maps API.
EAzureMapsTilesetId TilesetId = EAzureMapsTilesetId::BaseRoad
 The tileset ID to use.
FString Language = "en-US"
 The language in which search results should be returned.
FString View = "US"
 The View parameter (also called the "user region" parameter) allows you to show the correct maps for a certain country/region for geopolitically disputed regions.
- Public Attributes inherited from UCesiumRasterOverlay
FString MaterialLayerKey = "Overlay0"
 The key to use to match this overlay to a material layer.
FRasterOverlayRendererOptions rendererOptions
 Sets the texture filter and texture group of raster tile images.
Protected Member Functions
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > CreateOverlay (const CesiumRasterOverlays::RasterOverlayOptions &options={}) override
- Protected Member Functions inherited from UCesiumRasterOverlay
Cesium3DTilesSelection::Tileset * FindTileset () const
virtual void OnAdd (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
virtual void OnRemove (Cesium3DTilesSelection::Tileset *pTileset, CesiumRasterOverlays::RasterOverlay *pOverlay)
Additional Inherited Members
- Public Member Functions inherited from UCesiumRasterOverlay
 UCesiumRasterOverlay ()
void AddToTileset ()
 Displays this raster overlay on its owning Cesium 3D Tileset Actor, without changing its activation state.
void RemoveFromTileset ()
 Stops displaying this raster overlay on its owning Cesium 3D Tileset Actor.
void Refresh ()
double GetMaximumScreenSpaceError () const
void SetMaximumScreenSpaceError (double Value)
int32 GetMaximumTextureSize () const
void SetMaximumTextureSize (int32 Value)
int32 GetMaximumSimultaneousTileLoads () const
void SetMaximumSimultaneousTileLoads (int32 Value)
int64 GetSubTileCacheBytes () const
void SetSubTileCacheBytes (int64 Value)
 Activates this raster overlay, which will display it on the Cesium3DTileset to which the component is attached, if it isn't already displayed.
 Deactivates this raster overlay.
virtual bool IsReadyForFinishDestroy () override
- Protected Attributes inherited from UCesiumRasterOverlay
double MaximumScreenSpaceError = 2.0
int32 MaximumTextureSize = 2048
int32 MaximumSimultaneousTileLoads = 20
int64 SubTileCacheBytes = 16 * 1024 * 1024
bool ShowCreditsOnScreen
 Whether or not to show credits of this raster overlay on screen.
If you're using Azure Maps via Cesium ion, use the "Cesium ion Raster Overlay" component instead.
Definition at line 90 of file CesiumAzureMapsRasterOverlay.h.
◆ CreateOverlay()
virtual std::unique_ptr< CesiumRasterOverlays::RasterOverlay > UCesiumAzureMapsRasterOverlay::CreateOverlay ( const CesiumRasterOverlays::RasterOverlayOptions & options = {})
overrideprotectedvirtual
◆ ApiVersion
FString UCesiumAzureMapsRasterOverlay::ApiVersion = "2024-04-01"
Definition at line 105 of file CesiumAzureMapsRasterOverlay.h.
◆ Key
FString UCesiumAzureMapsRasterOverlay::Key
Definition at line 99 of file CesiumAzureMapsRasterOverlay.h.
◆ Language
FString UCesiumAzureMapsRasterOverlay::Language = "en-US"
This should be one of the supported IETF language tags, case insensitive. When data in the specified language is not available for a specific field, default language is used.
Definition at line 120 of file CesiumAzureMapsRasterOverlay.h.
◆ TilesetId
EAzureMapsTilesetId UCesiumAzureMapsRasterOverlay::TilesetId = EAzureMapsTilesetId::BaseRoad
Definition at line 111 of file CesiumAzureMapsRasterOverlay.h.
◆ View
FString UCesiumAzureMapsRasterOverlay::View = "US"
Different countries/regions have different views of such regions, and the View parameter allows your application to comply with the view required by the country/region your application will be serving. By default, the View parameter is set to "Unified" even if you haven't defined it in the request. It is your responsibility to determine the location of your users, and then set the View parameter correctly for that location. Alternatively, you have the option to set 'View=Auto', which will return the map data based on the IP address of the request. The View parameter in Azure Maps must be used in compliance with applicable laws, including those regarding mapping, of the country/region where maps, images and other data and third party content that you are authorized to access via Azure Maps is made available. Example: view=IN.
Definition at line 141 of file CesiumAzureMapsRasterOverlay.h.
