CesiumGlobeAnchorComponent.h
5#include "Cesium3DTileset.h"
6#include "CesiumGeospatial/GlobeAnchor.h"
7#include "Components/ActorComponent.h"
8#include "Delegates/IDelegateInstance.h"
9#include "CesiumGlobeAnchorComponent.generated.h"
10
13
14/**
15 * The frame of reference from which to interpret a given height value.
16 */
17UENUM(BlueprintType)
18enum class ECesiumHeightReference : uint8 {
19 /**
20 * Height is interpreted relative to the ellipsoid.
21 */
23 /**
24 * Height is interpreted relative to the surface of a 3D tileset.
25 */
27 /**
28 * No specified Height Reference. Used only for HeightReferenceOverride
29 * in the CesiumGlobeAnchor Blueprints. Do not use otherwise.
30 */
32};
33
34/**
35 * This component can be added to a movable actor to anchor it to the globe
36 * and maintain precise placement. When the owning actor is transformed through
37 * normal Unreal Engine mechanisms, the internal geospatial coordinates will be
38 * automatically updated. The actor position can also be set in terms of
39 * Earth-Centered, Earth-Fixed coordinates (ECEF) or Longitude, Latitude, and
40 * Height relative to the ellipsoid.
41 */
42UCLASS(ClassGroup = Cesium, Meta = (BlueprintSpawnableComponent))
43class CESIUMRUNTIME_API UCesiumGlobeAnchorComponent : public UActorComponent {
44 GENERATED_BODY()
45
46#pragma region Properties
47private:
48 /**
49 * The designated georeference actor controlling how the owning actor's
50 * coordinate system relates to the coordinate system in this Unreal Engine
51 * level.
52 *
53 * If this is null, the Component will find and use the first Georeference
54 * Actor in the level, or create one if necessary. To get the active/effective
55 * Georeference from Blueprints or C++, use ResolvedGeoreference instead.
56 *
57 * If setting this property changes the CesiumGeoreference, the globe position
58 * will be maintained and the Actor's transform will be updated according to
59 * the new CesiumGeoreference.
60 */
61 UPROPERTY(
62 EditAnywhere,
63 BlueprintReadWrite,
64 BlueprintGetter = GetGeoreference,
65 BlueprintSetter = SetGeoreference,
66 Category = "Cesium",
67 Meta = (AllowPrivateAccess))
68 TSoftObjectPtr<ACesiumGeoreference> Georeference = nullptr;
69
70 /**
71 * The frame of reference in which to interpret the object's height.
72 *
73 * `Ellipsoid` indicates the object's height above the ellipsoid set on the
74 * CesiumGeoreference. The object will remain at this height unless it is
75 * otherwise changed.
76 *
77 * `Tileset` indicates a height above a given tileset. The object will move
78 * vertically to maintain the specified height.
79 */
80 UPROPERTY(
81 EditAnywhere,
82 BlueprintReadWrite,
83 BlueprintGetter = GetHeightReference,
84 BlueprintSetter = SetHeightReference,
85 Category = "Cesium",
86 Meta =
87 (AllowPrivateAccess,
88 ReturnDisplayName = "Height Reference",
89 InvalidEnumValues = "None"))
91
92 /**
93 * The tileset actor to use as a height reference for the object. The object
94 * will maintain its height relative to this tileset even through movement or
95 * level-of-detail transitions. Only used when `HeightReference` is set to
96 * `Tileset`.
97 */
98 UPROPERTY(
99 EditAnywhere,
100 BlueprintReadWrite,
101 BlueprintGetter = GetReferencedTileset,
102 BlueprintSetter = SetReferencedTileset,
103 Category = "Cesium",
104 Meta = (AllowPrivateAccess))
105 TSoftObjectPtr<ACesium3DTileset> ReferencedTileset = nullptr;
106
107 /**
108 * The interval, in Ticks, in which to update the object's height when
109 * `HeightReference` is set to `Tileset`.
110 *
111 * A value of 1 causes `Height` to be updated on every Tick.
112 */
113 UPROPERTY(
114 EditAnywhere,
115 BlueprintReadWrite,
116 BlueprintGetter = GetHeightUpdateInterval,
117 BlueprintSetter = SetHeightUpdateInterval,
118 Category = "Cesium",
119 Meta = (AllowPrivateAccess, ReturnDisplayName = "Height Update Interval"))
120 int HeightUpdateInterval = 1;
121
122 /**
123 * The resolved georeference used by this component. This is not serialized
124 * because it may point to a Georeference in the PersistentLevel while this
125 * component is in a sub-level. If the Georeference property is specified,
126 * however then this property will have the same value.
127 *
128 * This property will be null before ResolveGeoreference is called, which
129 * happens automatically when the component is registered.
130 */
131 UPROPERTY(
132 Transient,
133 VisibleAnywhere,
134 BlueprintReadOnly,
135 BlueprintGetter = GetResolvedGeoreference,
136 Category = "Cesium",
137 Meta = (AllowPrivateAccess))
138 ACesiumGeoreference* ResolvedGeoreference = nullptr;
139
140 /**
141 * Whether to adjust the Actor's orientation based on globe curvature as the
142 * Actor moves.
143 *
144 * The Earth is not flat, so as we move across its surface, the direction of
145 * "up" changes. If we ignore this fact and leave an object's orientation
146 * unchanged as it moves over the globe surface, the object will become
147 * increasingly tilted and eventually be completely upside-down when we arrive
148 * at the opposite side of the globe.
149 *
150 * When this setting is enabled, this Component will automatically apply a
151 * rotation to the Actor to account for globe curvature any time the Actor's
152 * position on the globe changes.
153 *
154 * This property should usually be enabled, but it may be useful to disable it
155 * when your application already accounts for globe curvature itself when it
156 * updates an Actor's position and orientation, because in that case the Actor
157 * would be over-rotated.
158 */
159 UPROPERTY(
160 EditAnywhere,
161 BlueprintReadWrite,
164 Category = "Cesium",
165 Meta = (AllowPrivateAccess))
166 bool AdjustOrientationForGlobeWhenMoving = true;
167
168 /**
169 * Whether to automatically detect changes in the Actor's root transform and
170 * update the precise globe coordinates accordingly.
171 *
172 * When this is property is false, the precise coordinates may become out of
173 * sync with the Actor's root transform. However, you can still directly set
174 * the precise coordinates, and its transform will update accordingly. You can
175 * also call Sync after changing the Actor's transform to manually update the
176 * precise coordinates.
177 *
178 * This property is ignored when `HeightReference` is set to `Tileset`.
179 */
180 UPROPERTY(
181 EditAnywhere,
182 BlueprintReadWrite,
183 BlueprintGetter = GetDetectTransformChanges,
184 BlueprintSetter = SetDetectTransformChanges,
185 Category = "Cesium",
186 Meta = (AllowPrivateAccess))
187 bool DetectTransformChanges = true;
188
189 /**
190 * Using the teleport flag will move objects to the updated transform
191 * immediately and without affecting their velocity. This is useful when
192 * working with physics actors that maintain an internal velocity which we do
193 * not want to change when updating location.
194 */
195 UPROPERTY(
196 EditAnywhere,
197 BlueprintReadWrite,
198 BlueprintGetter = GetTeleportWhenUpdatingTransform,
199 BlueprintSetter = SetTeleportWhenUpdatingTransform,
200 Category = "Cesium",
201 Meta = (AllowPrivateAccess))
202 bool TeleportWhenUpdatingTransform = true;
203
204 /**
205 * The 4x4 transformation matrix from the Actor's local coordinate system to
206 * the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
207 *
208 * The ECEF coordinate system is a right-handed system located at the center
209 * of the Earth. The +X axis points to the intersection of the Equator and
210 * Prime Meridian (zero degrees longitude). The +Y axis points to the
211 * intersection of the Equator and +90 degrees longitude. The +Z axis points
212 * up through the North Pole.
213 *
214 * If `AdjustOrientationForGlobeWhenMoving` is enabled and this property is
215 * set, the Actor's orientation will also be adjusted to account for globe
216 * curvature.
217 */
218 UPROPERTY(
219 BlueprintReadWrite,
222 Category = "Cesium",
223 Meta = (AllowPrivateAccess))
224 FMatrix ActorToEarthCenteredEarthFixedMatrix;
225
226#pragma endregion
227
228#pragma region Property Accessors
229public:
230 /**
231 * Gets the designated georeference actor controlling how the owning actor's
232 * coordinate system relates to the coordinate system in this Unreal Engine
233 * level.
234 *
235 * If this is null, the Component will find and use the first Georeference
236 * Actor in the level, or create one if necessary. To get the active/effective
237 * Georeference from Blueprints or C++, use ResolvedGeoreference instead.
238 */
239 UFUNCTION(BlueprintGetter)
240 TSoftObjectPtr<ACesiumGeoreference> GetGeoreference() const;
241
242 /**
243 * Sets the designated georeference actor controlling how the owning actor's
244 * coordinate system relates to the coordinate system in this Unreal Engine
245 * level.
246 *
247 * If this is null, the Component will find and use the first Georeference
248 * Actor in the level, or create one if necessary. To get the active/effective
249 * Georeference from Blueprints or C++, use ResolvedGeoreference instead.
250 */
251 UFUNCTION(BlueprintSetter)
252 void
253 SetGeoreference(const TSoftObjectPtr<ACesiumGeoreference>& NewGeoreference);
254
255 UFUNCTION(BlueprintGetter, Category = "Cesium")
257
258 UFUNCTION(BlueprintSetter, Category = "Cesium")
260
261 UFUNCTION(
262 BlueprintGetter,
263 Category = "Cesium",
264 Meta = (ReturnDisplayName = "Referenced Tileset"))
265 TSoftObjectPtr<ACesium3DTileset> GetReferencedTileset() const;
266
267 UFUNCTION(BlueprintSetter, Category = "Cesium")
268 void SetReferencedTileset(const TSoftObjectPtr<ACesium3DTileset>& NewTileset);
269
270 UFUNCTION(BlueprintGetter, Category = "Cesium")
272
273 UFUNCTION(BlueprintSetter, Category = "Cesium")
274 void SetHeightUpdateInterval(int NewHeightReferenceUpdateInterval);
275
276 /**
277 * Gets the resolved georeference used by this component. This is not
278 * serialized because it may point to a Georeference in the PersistentLevel
279 * while this component is in a sub-level. If the Georeference property is
280 * manually specified, however, then this property will have the same value.
281 *
282 * This property will be null before ResolveGeoreference is called, which
283 * happens automatically when the component is registered.
284 */
285 UFUNCTION(BlueprintGetter, Category = "Cesium")
287
288 /**
289 * Resolves the Cesium Georeference to use with this Component. Returns
290 * the value of the Georeference property if it is set. Otherwise, finds a
291 * Georeference in the World and returns it, creating it if necessary. The
292 * resolved Georeference is cached so subsequent calls to this function will
293 * return the same instance, unless ForceReresolve is true.
294 */
295 UFUNCTION(BlueprintCallable, Category = "Cesium")
296 ACesiumGeoreference* ResolveGeoreference(bool bForceReresolve = false);
297
298 /**
299 * Obtains the (@ref UCesiumEllipsoid) set on the georeference used by this
300 * component.
301 */
302 UFUNCTION(BlueprintGetter, Category = "Cesium")
304
305 /**
306 * Gets the 4x4 transformation matrix from the Actor's local coordinate
307 * system to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
308 *
309 * The ECEF coordinate system is a right-handed system located at the center
310 * of the Earth. The +X axis points to the intersection of the Equator and
311 * Prime Meridian (zero degrees longitude). The +Y axis points to the
312 * intersection of the Equator and +90 degrees longitude. The +Z axis points
313 * up through the North Pole.
314 */
315 UFUNCTION(BlueprintGetter, Category = "Cesium")
317
318 /**
319 * Sets the 4x4 transformation matrix from the Actor's local coordinate
320 * system to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
321 *
322 * The ECEF coordinate system is a right-handed system located at the center
323 * of the Earth. The +X axis points to the intersection of the Equator and
324 * Prime Meridian (zero degrees longitude). The +Y axis points to the
325 * intersection of the Equator and +90 degrees longitude. The +Z axis points
326 * up through the North Pole.
327 *
328 * If `AdjustOrientationForGlobeWhenMoving` is enabled, the Actor's
329 * orientation will also be adjusted to account for globe curvature.
330 */
331 UFUNCTION(BlueprintSetter, Category = "Cesium")
332 void SetActorToEarthCenteredEarthFixedMatrix(const FMatrix& Value);
333
334 /**
335 * Gets a flag indicating whether to move objects to the updated transform
336 * immediately and without affecting their velocity. This is useful when
337 * working with physics actors that maintain an internal velocity which we do
338 * not want to change when updating location.
339 */
340 UFUNCTION(BlueprintGetter, Category = "Cesium")
342
343 /**
344 * Sets a flag indicating whether to move objects to the updated transform
345 * immediately and without affecting their velocity. This is useful when
346 * working with physics actors that maintain an internal velocity which we do
347 * not want to change when updating location.
348 */
349 UFUNCTION(BlueprintSetter, Category = "Cesium")
351
352 /**
353 * Gets a flag indicating whether to adjust the Actor's orientation based on
354 * globe curvature as the Actor moves.
355 *
356 * The Earth is not flat, so as we move across its surface, the direction of
357 * "up" changes. If we ignore this fact and leave an object's orientation
358 * unchanged as it moves over the globe surface, the object will become
359 * increasingly tilted and eventually be completely upside-down when we arrive
360 * at the opposite side of the globe.
361 *
362 * When this setting is enabled, this Component will automatically apply a
363 * rotation to the Actor to account for globe curvature any time the Actor's
364 * position on the globe changes.
365 *
366 * This property should usually be enabled, but it may be useful to disable it
367 * when your application already accounts for globe curvature itself when it
368 * updates an Actor's position and orientation, because in that case the Actor
369 * would be over-rotated.
370 */
371 UFUNCTION(BlueprintGetter, Category = "Cesium")
373
374 /**
375 * Sets a flag indicating whether to adjust the Actor's orientation based on
376 * globe curvature as the Actor moves.
377 *
378 * The Earth is not flat, so as we move across its surface, the direction of
379 * "up" changes. If we ignore this fact and leave an object's orientation
380 * unchanged as it moves over the globe surface, the object will become
381 * increasingly tilted and eventually be completely upside-down when we arrive
382 * at the opposite side of the globe.
383 *
384 * When this setting is enabled, this Component will automatically apply a
385 * rotation to the Actor to account for globe curvature any time the Actor's
386 * position on the globe changes.
387 *
388 * This property should usually be enabled, but it may be useful to disable it
389 * when your application already accounts for globe curvature itself when it
390 * updates an Actor's position and orientation, because in that case the Actor
391 * would be over-rotated.
392 */
393 UFUNCTION(BlueprintSetter, Category = "Cesium")
395
396 /**
397 * Gets a flag indicating whether to update the globe anchor when the Actor's
398 * transform changes.
399 *
400 * This property should usually be enabled, but it may be useful to disable it
401 * for performance reasons.
402 */
403 UFUNCTION(BlueprintGetter, Category = "Cesium")
405
406 /**
407 * Sets a flag indicating whether to update the globe anchor when the Actor's
408 * transform changes.
409 *
410 * This property should usually be enabled, but it may be useful to disable it
411 * for performance reasons.
412 */
413
414 UFUNCTION(BlueprintSetter, Category = "Cesium")
416
417#pragma endregion
418
419#pragma region Public Methods
421
422public:
423 /**
424 * Gets the longitude in degrees (X), latitude in degrees (Y), and height in
425 * meters relative to the specified height reference.
426 *
427 * `HeightReferenceOverride` can be optionally used to change the height
428 * reference in which the value is returned. When this is `None`, the
429 * `HeightReference` on the component will be used.
430 *
431 * For a `Tileset` height reference, if a `ReferencedTileset` is set, the
432 * returned value is the height in meters above the reference tileset.
433 *
434 * For an `Ellipsoid` height reference, the returned value is the height above
435 * the ellipsoid in meters. Do not confuse the ellipsoid height with a geoid
436 * height or height above mean sea level, which can be tens of meters higher
437 * or lower depending on where in the world the object is located.
438 */
439 UFUNCTION(
440 BlueprintPure,
441 Category = "Cesium",
442 Meta = (ReturnDisplayName = "LongitudeLatitudeHeight"))
444 const ECesiumHeightReference HeightReferenceOverride =
446
447 /**
448 * Gets the longitude in degrees.
449 */
450 UFUNCTION(
451 BlueprintPure,
452 Category = "Cesium",
453 Meta = (ReturnDisplayName = "Longitude"))
454 double GetLongitude() const { return this->GetLongitudeLatitudeHeight().X; }
455
456 /**
457 * Gets the latitude in degrees.
458 */
459 UFUNCTION(
460 BlueprintPure,
461 Category = "Cesium",
462 Meta = (ReturnDisplayName = "Latitude"))
463 double GetLatitude() const { return this->GetLongitudeLatitudeHeight().Y; }
464
465 /**
466 * Gets the height in meters above the specified height reference.
467 *
468 * `HeightReferenceOverride` can be optionally used to change the height
469 * reference in which the value is returned. When this is `None`, the
470 * `HeightReference` on the component will be used.
471 *
472 * For a `Tileset` height reference, if a `ReferencedTileset` is set, the
473 * returned value is the height in meters above the reference tileset.
474 *
475 * For an `Ellipsoid` height reference, the returned value is the height above
476 * the ellipsoid in meters. Do not confuse the ellipsoid height with a geoid
477 * height or height above mean sea level, which can be tens of meters higher
478 * or lower depending on where in the world the object is located.
479 */
480 UFUNCTION(
481 BlueprintPure,
482 Category = "Cesium",
483 Meta = (ReturnDisplayName = "Height"))
484 double GetHeight(
485 const ECesiumHeightReference HeightReferenceOverride =
487
488 /**
489 * Moves the Actor to which this component is attached to a given longitude in
490 * degrees (X), latitude in degrees (Y), and height in meters (Z) above the
491 * specified height reference.
492 *
493 * `HeightReferenceOverride` can be optionally used to change the height
494 * reference in which the value is returned. When this is `None`, the
495 * `HeightReference` on the component will be used.
496 *
497 * For a `Tileset` height reference, if a `ReferencedTileset` is set, the
498 * returned value is the height in meters above the reference tileset.
499 *
500 * For an `Ellipsoid` height reference, the returned value is the height above
501 * the ellipsoid in meters. Do not confuse the ellipsoid height with a geoid
502 * height or height above mean sea level, which can be tens of meters higher
503 * or lower depending on where in the world the object is located.
504 *
505 * If `AdjustOrientationForGlobeWhenMoving` is enabled, the Actor's
506 * orientation will also be adjusted to account for globe curvature.
507 */
508 UFUNCTION(BlueprintCallable, Category = "Cesium")
510 const FVector& LongitudeLatitudeHeight,
511 const ECesiumHeightReference HeightReferenceOverride =
513
514 /**
515 * Gets the Earth-Centered, Earth-Fixed (ECEF) coordinates of the Actor in
516 * meters.
517 */
518 UFUNCTION(
519 BlueprintPure,
520 Category = "Cesium",
521 meta = (ReturnDisplayName = "EarthCenteredEarthFixedPosition"))
523
524 /**
525 * Moves the Actor to which this component is attached to a given globe
526 * position in Earth-Centered, Earth-Fixed coordinates in meters.
527 *
528 * If AdjustOrientationForGlobeWhenMoving is enabled, this method will
529 * also update the orientation based on the globe curvature.
530 *
531 * @param EarthCenteredEarthFixedPosition The new position.
532 */
533 UFUNCTION(BlueprintCallable, Category = "Cesium")
535 const FVector& EarthCenteredEarthFixedPosition);
536
537 /**
538 * Gets the rotation of the Actor relative to a local coordinate system
539 * centered on this object where the +X points in the local East direction,
540 * the +Y axis points in the local South direction, and the +Z axis points in
541 * the local Up direction.
542 */
543 UFUNCTION(
544 BlueprintPure,
545 Category = "Cesium",
546 meta = (ReturnDisplayName = "EastSouthUpRotation"))
548
549 /**
550 * Sets the rotation of the Actor relative to a local coordinate system
551 * centered on this object where the +X points in the local East direction,
552 * the +Y axis points in the local South direction, and the +Z axis points in
553 * the local Up direction.
554 *
555 * When the rotation is set via this method, it is internally converted to
556 * and stored in the ActorToEarthCenteredEarthFixedMatrix property. As a
557 * result, getting this property will not necessarily return the exact value
558 * that was set.
559 */
560 UFUNCTION(BlueprintCallable, Category = "Cesium")
561 void SetEastSouthUpRotation(const FQuat& EastSouthUpRotation);
562
563 /**
564 * Gets the rotation of the Actor relative to the Earth-Centered, Earth-Fixed
565 * (ECEF) coordinate system.
566 *
567 * The ECEF coordinate system is a right-handed system located at the center
568 * of the Earth. The +X axis points from there to the intersection of the
569 * Equator and Prime Meridian (zero degrees longitude). The +Y axis points to
570 * the intersection of the Equator and +90 degrees longitude. The +Z axis
571 * points up through the North Pole.
572 */
573 UFUNCTION(
574 BlueprintPure,
575 Category = "Cesium",
576 meta = (ReturnDisplayName = "EarthCenteredEarthFixedRotation"))
578
579 /**
580 * Sets the rotation of the Actor relative to the Earth-Centered, Earth-Fixed
581 * (ECEF) coordinate system.
582 *
583 * The ECEF coordinate system is a right-handed system located at the center
584 * of the Earth. The +X axis points from there to the intersection of the
585 * Equator and Prime Meridian (zero degrees longitude). The +Y axis points to
586 * the intersection of the Equator and +90 degrees longitude. The +Z axis
587 * points up through the North Pole.
588 */
589 UFUNCTION(BlueprintCallable, Category = "Cesium")
591 const FQuat& EarthCenteredEarthFixedRotation);
592
593 /**
594 * Rotates the Actor so that its local +Z axis is aligned with the ellipsoid
595 * surface normal at its current location.
596 */
597 UFUNCTION(BlueprintCallable, Category = "Cesium")
599
600 /**
601 * Rotates the Actor so that its +X axis points in the local East direction,
602 * its +Y axis points in the local South direction, and its +Z axis points in
603 * the local Up direction.
604 */
605 UFUNCTION(BlueprintCallable, Category = "Cesium")
607
608 /**
609 * Synchronizes the properties of this globe anchor.
610 *
611 * It is usually not necessary to call this method because it is called
612 * automatically when needed.
613 *
614 * This method performs the following actions:
615 *
616 * - If the ActorToEarthCenteredEarthFixedMatrix has not yet been
617 * determined, it is computed from the Actor's current root transform.
618 * - If the Actor's root transform has changed since the last time this
619 * component was registered, this method updates the
620 * ActorToEarthCenteredEarthFixedMatrix from the current transform.
621 * - If the origin of the CesiumGeoreference has changed, the Actor's root
622 * transform is updated based on the ActorToEarthCenteredEarthFixedMatrix and
623 * the new georeference origin.
624 * - This synchronization works even if DetectTransformChanges is false.
625 */
626 UFUNCTION(BlueprintCallable, Category = "Cesium")
627 void Sync();
628
629#pragma endregion
630
631#pragma region Obsolete
632public:
633 /**
634 * @brief DEPRECATED
635 * @deprecated The resolved georeference can no longer be explicitly
636 * invalidated. To change the georeference, call SetGeoreference or
637 * ReregisterComponent.
638 */
639 UE_DEPRECATED(
640 "Cesium For Unreal v2.0",
641 "The resolved georeference can no longer be explicitly invalidated. To change the georeference, call SetGeoreference or ReregisterComponent.")
642 UFUNCTION(
643 BlueprintCallable,
644 Category = "Cesium",
645 Meta =
646 (DeprecatedFunction,
647 DeprecationMessage =
648 "The resolved georeference can no longer be explicitly invalidated. To change the georeference, call SetGeoreference or ReregisterComponent."))
650#pragma endregion
651
652#pragma region Unreal Lifecycle
653protected:
654 /**
655 * Handles reading, writing, and reference collecting using FArchive.
656 * This implementation handles all FProperty serialization, but can be
657 * overridden for native variables.
658 *
659 * This class overrides this method to ensure internal variables are
660 * immediately synchronized with newly-loaded values.
661 */
662 virtual void Serialize(FArchive& Ar) override;
663
664 /**
665 * Called when a component is created (not loaded). This can happen in the
666 * editor or during gameplay.
667 *
668 * This method is invoked after this component is pasted and just prior to
669 * registration. We mark the globe transform invalid here because we can't
670 * assume the globe transform is still valid when the component is pasted into
671 * another Actor, or even if the Actor was changed since the Component was
672 * copied.
673 */
674 virtual void OnComponentCreated() override;
675
676#if WITH_EDITOR
677 virtual void
678 PostEditChangeProperty(FPropertyChangedEvent& PropertyChangedEvent) override;
679#endif
680
681 /**
682 * Called when a component is registered. This can be viewed as "enabling"
683 * this Component on the Actor to which it is attached.
684 *
685 * In the Editor, this is called in a many different situations, such as on
686 * changes to properties.
687 */
688 virtual void OnRegister() override;
689
690 /**
691 * Called when a component is unregistered. This can be viewed as
692 * "disabling" this Component on the Actor to which it is attached.
693 *
694 * In the Editor, this is called in a many different situations, such as on
695 * changes to properties.
696 */
697 virtual void OnUnregister() override;
698#pragma endregion
699
700protected:
701 virtual void TickComponent(
702 float DeltaTime,
703 ELevelTick TickType,
704 FActorComponentTickFunction* ThisTickFunction) override;
705
706#pragma region Implementation Details
707private:
708 int _heightReferenceUpdateCounter = 0;
709
710 /**
711 * When HeightReference is Tileset, this is the target height
712 * above the tileset to maintain.
713 */
714 UPROPERTY()
715 float _fixedHeightAboveHeightReference = 0.0f;
716
717 /**
718 * Calculate correct Height from the actor's position based on the
719 * HeightReference and tileset.
720 */
721 bool _setHeightFromTilesetReference();
722
723 /**
724 * Determines if HeightReference is Tileset and ReferencedTileset is set.
725 */
726 bool _isUsingTilesetHeightReference(
727 const ECesiumHeightReference heightReferenceOverride =
729
730 /**
731 * Compute a down vector at the specified position in Unreal coordinates
732 */
733 FVector _computeLocalDown(
734 const ACesiumGeoreference* pGeoreference,
735 const FVector& unrealWorldPosition) const;
736
737 /**
738 * Project the component's position onto the tileset specified by
739 * ReferencedTileset, Returns whether an intersection was found.
740 *
741 * alternateActorPosition optionally specifies an alternate position from
742 * which to start the intersection test in Longitude/Latitude/Height
743 * coordinates.
744 */
745 bool _queryLongitudeLatitudeHeightPositionOnTileset(
746 FVector& groundIntersection,
747 const std::optional<FVector>& alternateStartPosition = std::nullopt);
748
749 CesiumGeospatial::GlobeAnchor _createNativeGlobeAnchor() const;
750
751 USceneComponent* _getRootComponent(bool warnIfNull) const;
752
753 FTransform _getCurrentRelativeTransform() const;
754
755 void _setCurrentRelativeTransform(const FTransform& relativeTransform);
756
757 CesiumGeospatial::GlobeAnchor
758 _createOrUpdateNativeGlobeAnchorFromRelativeTransform(
759 const FTransform& newRelativeTransform);
760
761 CesiumGeospatial::GlobeAnchor
762 _createOrUpdateNativeGlobeAnchorFromECEF(const FMatrix& newActorToECEFMatrix);
763
764 void _updateFromNativeGlobeAnchor(
765 const CesiumGeospatial::GlobeAnchor& nativeAnchor);
766
767 void _setNewActorToECEFFromRelativeTransform();
768
769#if WITH_EDITORONLY_DATA
770 // This is used only to preserve the transformation saved by old versions of
771 // Cesium for Unreal. See the Serialize method.
772 UPROPERTY(Meta = (DeprecatedProperty))
773 double _actorToECEF_Array_DEPRECATED[16];
774#endif
775
776 /**
777 * True if the globe transform is a valid and correct representation of the
778 * position and orientation of this Actor. False if the globe transform has
779 * not yet been computed and so the Actor transform is the only valid
780 * representation of the Actor's position and orientation.
781 */
782 UPROPERTY()
783 bool _actorToECEFIsValid = false;
784
785 /**
786 * Whether an update of the actor transform is currently in progress,
787 * and further calls that are received by _onActorTransformChanged
788 * should be ignored
789 */
790 bool _updatingActorTransform = false;
791
792 bool _lastRelativeTransformIsValid = false;
793 FTransform _lastRelativeTransform{};
794
795 /**
796 * Called when the root transform of the Actor to which this Component is
797 * attached has changed. So:
798 * * The globe (ECEF) position and orientation are computed from the new
799 * transform.
800 * * When `AdjustOrientationForGlobeWhenMoving` is enabled, the orientation
801 * will also be adjusted for globe curvature.
802 */
803 void _onActorTransformChanged(
804 USceneComponent* InRootComponent,
805 EUpdateTransformFlags UpdateTransformFlags,
806 ETeleportType Teleport);
807
808 /**
809 * Called when the Component switches to a new Georeference Actor or the
810 * existing Georeference is given a new origin Longitude, Latitude, or
811 * Height. The Actor's position and orientation are recomputed from the
812 * Component's globe (ECEF) position and orientation.
813 */
814 UFUNCTION(CallInEditor)
815 void _onGeoreferenceChanged();
816
818#pragma endregion
819};
@ Tileset
@ None
@ Ellipsoid
Controls how global geospatial coordinates are mapped to coordinates in the Unreal Engine level.
void SetReferencedTileset(const TSoftObjectPtr< ACesium3DTileset > &NewTileset)
double GetHeight(const ECesiumHeightReference HeightReferenceOverride=ECesiumHeightReference::None) const
FVector GetLongitudeLatitudeHeight(const ECesiumHeightReference HeightReferenceOverride=ECesiumHeightReference::None) const
Gets the longitude in degrees (X), latitude in degrees (Y), and height in meters relative to the spec...
FQuat GetEastSouthUpRotation() const
Gets the rotation of the Actor relative to a local coordinate system centered on this object where th...
FVector GetEarthCenteredEarthFixedPosition() const
Gets the Earth-Centered, Earth-Fixed (ECEF) coordinates of the Actor in meters.
void SetEastSouthUpRotation(const FQuat &EastSouthUpRotation)
Sets the rotation of the Actor relative to a local coordinate system centered on this object where th...
TSoftObjectPtr< ACesium3DTileset > GetReferencedTileset() const
ECesiumHeightReference GetHeightReference() const
void SetDetectTransformChanges(bool Value)
Sets a flag indicating whether to update the globe anchor when the Actor's transform changes.
void SetHeightReference(ECesiumHeightReference NewHeightReference)
void MoveToEarthCenteredEarthFixedPosition(const FVector &EarthCenteredEarthFixedPosition)
Moves the Actor to which this component is attached to a given globe position in Earth-Centered,...
int GetHeightUpdateInterval() const
virtual void TickComponent(float DeltaTime, ELevelTick TickType, FActorComponentTickFunction *ThisTickFunction) override
FMatrix GetActorToEarthCenteredEarthFixedMatrix() const
Gets the 4x4 transformation matrix from the Actor's local coordinate system to the Earth-Centered,...
virtual void Serialize(FArchive &Ar) override
void SetAdjustOrientationForGlobeWhenMoving(bool Value)
Sets a flag indicating whether to adjust the Actor's orientation based on globe curvature as the Acto...
bool GetTeleportWhenUpdatingTransform() const
Gets a flag indicating whether to move objects to the updated transform immediately and without affec...
void Sync()
void SnapLocalUpToEllipsoidNormal()
Rotates the Actor so that its local +Z axis is aligned with the ellipsoid surface normal at its curre...
void SetActorToEarthCenteredEarthFixedMatrix(const FMatrix &Value)
Sets the 4x4 transformation matrix from the Actor's local coordinate system to the Earth-Centered,...
TSoftObjectPtr< ACesiumGeoreference > GetGeoreference() const
Gets the designated georeference actor controlling how the owning actor's coordinate system relates t...
void SetGeoreference(const TSoftObjectPtr< ACesiumGeoreference > &NewGeoreference)
Sets the designated georeference actor controlling how the owning actor's coordinate system relates t...
void SetTeleportWhenUpdatingTransform(bool Value)
Sets a flag indicating whether to move objects to the updated transform immediately and without affec...
void SetEarthCenteredEarthFixedRotation(const FQuat &EarthCenteredEarthFixedRotation)
Sets the rotation of the Actor relative to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
void InvalidateResolvedGeoreference()
DEPRECATED.
void MoveToLongitudeLatitudeHeight(const FVector &LongitudeLatitudeHeight, const ECesiumHeightReference HeightReferenceOverride=ECesiumHeightReference::None)
Moves the Actor to which this component is attached to a given longitude in degrees (X),...
bool GetDetectTransformChanges() const
Gets a flag indicating whether to update the globe anchor when the Actor's transform changes.
void SnapToEastSouthUp()
Rotates the Actor so that its +X axis points in the local East direction, its +Y axis points in the l...
bool GetAdjustOrientationForGlobeWhenMoving() const
Gets a flag indicating whether to adjust the Actor's orientation based on globe curvature as the Acto...
UCesiumEllipsoid * GetEllipsoid() const
Obtains the (UCesiumEllipsoid) set on the georeference used by this component.
ACesiumGeoreference * GetResolvedGeoreference() const
FQuat GetEarthCenteredEarthFixedRotation() const
Gets the rotation of the Actor relative to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
ACesiumGeoreference * ResolveGeoreference(bool bForceReresolve=false)
STL namespace.
