UCesiumGlobeAnchorComponent Class Reference
This component can be added to a movable actor to anchor it to the globe and maintain precise placement. More...
#include <CesiumGlobeAnchorComponent.h>
Inheritance diagram for UCesiumGlobeAnchorComponent:
TSoftObjectPtr< ACesiumGeoreference > GetGeoreference () const
 Gets the designated georeference actor controlling how the owning actor's coordinate system relates to the coordinate system in this Unreal Engine level.
void SetGeoreference (const TSoftObjectPtr< ACesiumGeoreference > &NewGeoreference)
 Sets the designated georeference actor controlling how the owning actor's coordinate system relates to the coordinate system in this Unreal Engine level.
ECesiumHeightReference GetHeightReference () const
void SetHeightReference (ECesiumHeightReference NewHeightReference)
TSoftObjectPtr< ACesium3DTileset > GetReferencedTileset () const
void SetReferencedTileset (const TSoftObjectPtr< ACesium3DTileset > &NewTileset)
int GetHeightUpdateInterval () const
void SetHeightUpdateInterval (int NewHeightReferenceUpdateInterval)
ACesiumGeoreference * GetResolvedGeoreference () const
 Gets the resolved georeference used by this component.
ACesiumGeoreference * ResolveGeoreference (bool bForceReresolve=false)
 Resolves the Cesium Georeference to use with this Component.
UCesiumEllipsoid * GetEllipsoid () const
 Obtains the (UCesiumEllipsoid) set on the georeference used by this component.
FMatrix GetActorToEarthCenteredEarthFixedMatrix () const
 Gets the 4x4 transformation matrix from the Actor's local coordinate system to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
void SetActorToEarthCenteredEarthFixedMatrix (const FMatrix &Value)
 Sets the 4x4 transformation matrix from the Actor's local coordinate system to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
bool GetTeleportWhenUpdatingTransform () const
 Gets a flag indicating whether to move objects to the updated transform immediately and without affecting their velocity.
void SetTeleportWhenUpdatingTransform (bool Value)
 Sets a flag indicating whether to move objects to the updated transform immediately and without affecting their velocity.
bool GetAdjustOrientationForGlobeWhenMoving () const
 Gets a flag indicating whether to adjust the Actor's orientation based on globe curvature as the Actor moves.
void SetAdjustOrientationForGlobeWhenMoving (bool Value)
 Sets a flag indicating whether to adjust the Actor's orientation based on globe curvature as the Actor moves.
bool GetDetectTransformChanges () const
 Gets a flag indicating whether to update the globe anchor when the Actor's transform changes.
void SetDetectTransformChanges (bool Value)
 Sets a flag indicating whether to update the globe anchor when the Actor's transform changes.
 UCesiumGlobeAnchorComponent ()
FVector GetLongitudeLatitudeHeight (const ECesiumHeightReference HeightReferenceOverride=ECesiumHeightReference::None) const
 Gets the longitude in degrees (X), latitude in degrees (Y), and height in meters relative to the specified height reference.
double GetLongitude () const
 Gets the longitude in degrees.
double GetLatitude () const
 Gets the latitude in degrees.
double GetHeight (const ECesiumHeightReference HeightReferenceOverride=ECesiumHeightReference::None) const
 Gets the height in meters above the specified height reference.
void MoveToLongitudeLatitudeHeight (const FVector &LongitudeLatitudeHeight, const ECesiumHeightReference HeightReferenceOverride=ECesiumHeightReference::None)
 Moves the Actor to which this component is attached to a given longitude in degrees (X), latitude in degrees (Y), and height in meters (Z) above the specified height reference.
FVector GetEarthCenteredEarthFixedPosition () const
 Gets the Earth-Centered, Earth-Fixed (ECEF) coordinates of the Actor in meters.
void MoveToEarthCenteredEarthFixedPosition (const FVector &EarthCenteredEarthFixedPosition)
 Moves the Actor to which this component is attached to a given globe position in Earth-Centered, Earth-Fixed coordinates in meters.
FQuat GetEastSouthUpRotation () const
 Gets the rotation of the Actor relative to a local coordinate system centered on this object where the +X points in the local East direction, the +Y axis points in the local South direction, and the +Z axis points in the local Up direction.
void SetEastSouthUpRotation (const FQuat &EastSouthUpRotation)
 Sets the rotation of the Actor relative to a local coordinate system centered on this object where the +X points in the local East direction, the +Y axis points in the local South direction, and the +Z axis points in the local Up direction.
FQuat GetEarthCenteredEarthFixedRotation () const
 Gets the rotation of the Actor relative to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
void SetEarthCenteredEarthFixedRotation (const FQuat &EarthCenteredEarthFixedRotation)
 Sets the rotation of the Actor relative to the Earth-Centered, Earth-Fixed (ECEF) coordinate system.
void SnapLocalUpToEllipsoidNormal ()
 Rotates the Actor so that its local +Z axis is aligned with the ellipsoid surface normal at its current location.
void SnapToEastSouthUp ()
 Rotates the Actor so that its +X axis points in the local East direction, its +Y axis points in the local South direction, and its +Z axis points in the local Up direction.
void Sync ()
 Synchronizes the properties of this globe anchor.
void InvalidateResolvedGeoreference ()
 DEPRECATED.
Protected Member Functions
virtual void Serialize (FArchive &Ar) override
 Handles reading, writing, and reference collecting using FArchive.
virtual void OnComponentCreated () override
 Called when a component is created (not loaded).
virtual void OnRegister () override
 Called when a component is registered.
virtual void OnUnregister () override
 Called when a component is unregistered.
virtual void TickComponent (float DeltaTime, ELevelTick TickType, FActorComponentTickFunction *ThisTickFunction) override
Friends
class FCesiumGlobeAnchorCustomization
When the owning actor is transformed through normal Unreal Engine mechanisms, the internal geospatial coordinates will be automatically updated. The actor position can also be set in terms of Earth-Centered, Earth-Fixed coordinates (ECEF) or Longitude, Latitude, and Height relative to the ellipsoid.
Definition at line 43 of file CesiumGlobeAnchorComponent.h.
◆ UCesiumGlobeAnchorComponent()
UCesiumGlobeAnchorComponent::UCesiumGlobeAnchorComponent ( )
◆ GetActorToEarthCenteredEarthFixedMatrix()
FMatrix UCesiumGlobeAnchorComponent::GetActorToEarthCenteredEarthFixedMatrix ( ) const
The ECEF coordinate system is a right-handed system located at the center of the Earth. The +X axis points to the intersection of the Equator and Prime Meridian (zero degrees longitude). The +Y axis points to the intersection of the Equator and +90 degrees longitude. The +Z axis points up through the North Pole.
◆ GetAdjustOrientationForGlobeWhenMoving()
bool UCesiumGlobeAnchorComponent::GetAdjustOrientationForGlobeWhenMoving ( ) const
The Earth is not flat, so as we move across its surface, the direction of "up" changes. If we ignore this fact and leave an object's orientation unchanged as it moves over the globe surface, the object will become increasingly tilted and eventually be completely upside-down when we arrive at the opposite side of the globe.
When this setting is enabled, this Component will automatically apply a rotation to the Actor to account for globe curvature any time the Actor's position on the globe changes.
This property should usually be enabled, but it may be useful to disable it when your application already accounts for globe curvature itself when it updates an Actor's position and orientation, because in that case the Actor would be over-rotated.
◆ GetDetectTransformChanges()
bool UCesiumGlobeAnchorComponent::GetDetectTransformChanges ( ) const
This property should usually be enabled, but it may be useful to disable it for performance reasons.
◆ GetEarthCenteredEarthFixedPosition()
FVector UCesiumGlobeAnchorComponent::GetEarthCenteredEarthFixedPosition ( ) const
◆ GetEarthCenteredEarthFixedRotation()
FQuat UCesiumGlobeAnchorComponent::GetEarthCenteredEarthFixedRotation ( ) const
The ECEF coordinate system is a right-handed system located at the center of the Earth. The +X axis points from there to the intersection of the Equator and Prime Meridian (zero degrees longitude). The +Y axis points to the intersection of the Equator and +90 degrees longitude. The +Z axis points up through the North Pole.
◆ GetEastSouthUpRotation()
FQuat UCesiumGlobeAnchorComponent::GetEastSouthUpRotation ( ) const
◆ GetEllipsoid()
UCesiumEllipsoid * UCesiumGlobeAnchorComponent::GetEllipsoid ( ) const
◆ GetGeoreference()
TSoftObjectPtr< ACesiumGeoreference > UCesiumGlobeAnchorComponent::GetGeoreference ( ) const
If this is null, the Component will find and use the first Georeference Actor in the level, or create one if necessary. To get the active/effective Georeference from Blueprints or C++, use ResolvedGeoreference instead.
◆ GetHeight()
double UCesiumGlobeAnchorComponent::GetHeight ( const ECesiumHeightReference HeightReferenceOverride = ECesiumHeightReference::None) const
HeightReferenceOverride can be optionally used to change the height reference in which the value is returned. When this is None, the HeightReference on the component will be used.
For a Tileset height reference, if a ReferencedTileset is set, the returned value is the height in meters above the reference tileset.
For an Ellipsoid height reference, the returned value is the height above the ellipsoid in meters. Do not confuse the ellipsoid height with a geoid height or height above mean sea level, which can be tens of meters higher or lower depending on where in the world the object is located.
◆ GetHeightReference()
ECesiumHeightReference UCesiumGlobeAnchorComponent::GetHeightReference ( ) const
◆ GetHeightUpdateInterval()
int UCesiumGlobeAnchorComponent::GetHeightUpdateInterval ( ) const
◆ GetLatitude()
double UCesiumGlobeAnchorComponent::GetLatitude ( ) const
Definition at line 463 of file CesiumGlobeAnchorComponent.h.
◆ GetLongitude()
double UCesiumGlobeAnchorComponent::GetLongitude ( ) const
Definition at line 454 of file CesiumGlobeAnchorComponent.h.
◆ GetLongitudeLatitudeHeight()
FVector UCesiumGlobeAnchorComponent::GetLongitudeLatitudeHeight ( const ECesiumHeightReference HeightReferenceOverride = ECesiumHeightReference::None) const
◆ GetReferencedTileset()
TSoftObjectPtr< ACesium3DTileset > UCesiumGlobeAnchorComponent::GetReferencedTileset ( ) const
◆ GetResolvedGeoreference()
ACesiumGeoreference * UCesiumGlobeAnchorComponent::GetResolvedGeoreference ( ) const
This is not serialized because it may point to a Georeference in the PersistentLevel while this component is in a sub-level. If the Georeference property is manually specified, however, then this property will have the same value.
This property will be null before ResolveGeoreference is called, which happens automatically when the component is registered.
◆ GetTeleportWhenUpdatingTransform()
bool UCesiumGlobeAnchorComponent::GetTeleportWhenUpdatingTransform ( ) const
This is useful when working with physics actors that maintain an internal velocity which we do not want to change when updating location.
◆ InvalidateResolvedGeoreference()
void UCesiumGlobeAnchorComponent::InvalidateResolvedGeoreference ( )
DEPRECATED.
Deprecated
The resolved georeference can no longer be explicitly invalidated. To change the georeference, call SetGeoreference or ReregisterComponent.
◆ MoveToEarthCenteredEarthFixedPosition()
void UCesiumGlobeAnchorComponent::MoveToEarthCenteredEarthFixedPosition ( const FVector & EarthCenteredEarthFixedPosition)
If AdjustOrientationForGlobeWhenMoving is enabled, this method will also update the orientation based on the globe curvature.
EarthCenteredEarthFixedPositionThe new position.
◆ MoveToLongitudeLatitudeHeight()
void UCesiumGlobeAnchorComponent::MoveToLongitudeLatitudeHeight ( const FVector & LongitudeLatitudeHeight,
const ECesiumHeightReference HeightReferenceOverride = ECesiumHeightReference::None )
If AdjustOrientationForGlobeWhenMoving is enabled, the Actor's orientation will also be adjusted to account for globe curvature.
◆ OnComponentCreated()
virtual void UCesiumGlobeAnchorComponent::OnComponentCreated ( )
overrideprotectedvirtual
This can happen in the editor or during gameplay.
This method is invoked after this component is pasted and just prior to registration. We mark the globe transform invalid here because we can't assume the globe transform is still valid when the component is pasted into another Actor, or even if the Actor was changed since the Component was copied.
◆ OnRegister()
virtual void UCesiumGlobeAnchorComponent::OnRegister ( )
This can be viewed as "enabling" this Component on the Actor to which it is attached.
In the Editor, this is called in a many different situations, such as on changes to properties.
◆ OnUnregister()
virtual void UCesiumGlobeAnchorComponent::OnUnregister ( )
This can be viewed as "disabling" this Component on the Actor to which it is attached.
◆ ResolveGeoreference()
ACesiumGeoreference * UCesiumGlobeAnchorComponent::ResolveGeoreference ( bool bForceReresolve = false)
Returns the value of the Georeference property if it is set. Otherwise, finds a Georeference in the World and returns it, creating it if necessary. The resolved Georeference is cached so subsequent calls to this function will return the same instance, unless ForceReresolve is true.
◆ Serialize()
virtual void UCesiumGlobeAnchorComponent::Serialize ( FArchive & Ar)
This implementation handles all FProperty serialization, but can be overridden for native variables.
This class overrides this method to ensure internal variables are immediately synchronized with newly-loaded values.
◆ SetActorToEarthCenteredEarthFixedMatrix()
void UCesiumGlobeAnchorComponent::SetActorToEarthCenteredEarthFixedMatrix ( const FMatrix & Value)
◆ SetAdjustOrientationForGlobeWhenMoving()
void UCesiumGlobeAnchorComponent::SetAdjustOrientationForGlobeWhenMoving ( bool Value)
◆ SetDetectTransformChanges()
void UCesiumGlobeAnchorComponent::SetDetectTransformChanges ( bool Value)
◆ SetEarthCenteredEarthFixedRotation()
void UCesiumGlobeAnchorComponent::SetEarthCenteredEarthFixedRotation ( const FQuat & EarthCenteredEarthFixedRotation)
◆ SetEastSouthUpRotation()
void UCesiumGlobeAnchorComponent::SetEastSouthUpRotation ( const FQuat & EastSouthUpRotation)
When the rotation is set via this method, it is internally converted to and stored in the ActorToEarthCenteredEarthFixedMatrix property. As a result, getting this property will not necessarily return the exact value that was set.
◆ SetGeoreference()
void UCesiumGlobeAnchorComponent::SetGeoreference ( const TSoftObjectPtr< ACesiumGeoreference > & NewGeoreference)
◆ SetHeightReference()
void UCesiumGlobeAnchorComponent::SetHeightReference ( ECesiumHeightReference NewHeightReference)
◆ SetHeightUpdateInterval()
void UCesiumGlobeAnchorComponent::SetHeightUpdateInterval ( int NewHeightReferenceUpdateInterval)
◆ SetReferencedTileset()
void UCesiumGlobeAnchorComponent::SetReferencedTileset ( const TSoftObjectPtr< ACesium3DTileset > & NewTileset)
◆ SetTeleportWhenUpdatingTransform()
void UCesiumGlobeAnchorComponent::SetTeleportWhenUpdatingTransform ( bool Value)
◆ SnapLocalUpToEllipsoidNormal()
void UCesiumGlobeAnchorComponent::SnapLocalUpToEllipsoidNormal ( )
◆ SnapToEastSouthUp()
void UCesiumGlobeAnchorComponent::SnapToEastSouthUp ( )
◆ Sync()
void UCesiumGlobeAnchorComponent::Sync ( )
It is usually not necessary to call this method because it is called automatically when needed.
This method performs the following actions:
  • If the ActorToEarthCenteredEarthFixedMatrix has not yet been determined, it is computed from the Actor's current root transform.
  • If the Actor's root transform has changed since the last time this component was registered, this method updates the ActorToEarthCenteredEarthFixedMatrix from the current transform.
  • If the origin of the CesiumGeoreference has changed, the Actor's root transform is updated based on the ActorToEarthCenteredEarthFixedMatrix and the new georeference origin.
  • This synchronization works even if DetectTransformChanges is false.
◆ TickComponent()
virtual void UCesiumGlobeAnchorComponent::TickComponent ( float DeltaTime,
FActorComponentTickFunction * ThisTickFunction )
◆ FCesiumGlobeAnchorCustomization
friend class FCesiumGlobeAnchorCustomization
friend
Definition at line 817 of file CesiumGlobeAnchorComponent.h.
