CesiumGltf::ImageSpec Struct Reference
Image data used to create a texture. Image MAY be referenced by a URI (or IRI) or a buffer view index. More...
#include <CesiumGltf/ImageSpec.h>
Inheritance diagram for CesiumGltf::ImageSpec:
CesiumGltf::NamedObject CesiumUtility::ExtensibleObject CesiumGltf::Image
Classes
struct  MimeType
 Known values for The image's media type. This field MUST be defined when bufferView is defined. More...
std::optional< std::string > uri
 The URI (or IRI) of the image.
std::optional< std::string > mimeType
int32_t bufferView = -1
 The index of the bufferView that contains the image. This field MUST NOT be defined when uri is defined.
std::string name
static constexpr const char * TypeName = "Image"
Protected Member Functions
 ImageSpec ()=default
 This class is not meant to be instantiated directly. Use Image instead.
Friends
struct Image
Definition at line 17 of file ImageSpec.h.
int64_t CesiumGltf::ImageSpec::getSizeBytes ( ) const
Definition at line 65 of file ImageSpec.h.
◆ Image
friend struct Image
friend
Definition at line 82 of file ImageSpec.h.
◆ bufferView
int32_t CesiumGltf::ImageSpec::bufferView = -1
Definition at line 57 of file ImageSpec.h.
◆ mimeType
std::optional<std::string> CesiumGltf::ImageSpec::mimeType
Known values are defined in MimeType.
Definition at line 51 of file ImageSpec.h.
const char* CesiumGltf::ImageSpec::TypeName = "Image"
Definition at line 21 of file ImageSpec.h.
◆ uri
std::optional<std::string> CesiumGltf::ImageSpec::uri
Relative paths are relative to the current glTF asset. Instead of referencing an external file, this field MAY contain a data:-URI. This field MUST NOT be defined when bufferView is defined.
Definition at line 42 of file ImageSpec.h.
