ImageSpec.h
6#include <CesiumGltf/NamedObject.h>
8#include <cstdint>
9#include <optional>
10#include <string>
11
12namespace CesiumGltf {
17struct CESIUMGLTF_API ImageSpec : public CesiumGltf::NamedObject {
21 static constexpr const char* TypeName = "Image";
22
27 struct MimeType {
29 inline static const std::string image_jpeg = "image/jpeg";
30
32 inline static const std::string image_png = "image/png";
33 };
34
42 std::optional<std::string> uri;
43
51 std::optional<std::string> mimeType;
52
57 int32_t bufferView = -1;
58
65 int64_t getSizeBytes() const {
66 int64_t accum = 0;
67 accum += int64_t(sizeof(ImageSpec));
69 int64_t(sizeof(CesiumGltf::NamedObject));
70 if (this->uri) {
71 accum += int64_t(this->uri->capacity() * sizeof(char));
72 }
73 return accum;
74 }
75
76protected:
81 ImageSpec() = default;
82 friend struct Image;
83};
84} // namespace CesiumGltf
Known values for The image's media type. This field MUST be defined when bufferView is defined.
Definition ImageSpec.h:27
image/jpeg
Definition ImageSpec.h:29
image/png
Definition ImageSpec.h:32
ImageSpec()=default
This class is not meant to be instantiated directly. Use Image instead.
std::optional< std::string > mimeType
Definition ImageSpec.h:51
Definition ImageSpec.h:21
int32_t bufferView
The index of the bufferView that contains the image. This field MUST NOT be defined when uri is defin...
Definition ImageSpec.h:57
std::optional< std::string > uri
The URI (or IRI) of the image.
Definition ImageSpec.h:42
Definition ImageSpec.h:65
Definition NamedObject.h:14
Definition NamedObject.h:28
