CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibility Struct Referencefinal
This class is not meant to be instantiated directly. Use ExtensionExtMeshPrimitiveEdgeVisibility instead. More...
#include <CesiumGltf/ExtensionExtMeshPrimitiveEdgeVisibility.h>
Inheritance diagram for CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibility:
CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec CesiumUtility::ExtensibleObject
Classes
struct  Visibility
 Known values for the visibility specified for a single edge. More...
Additional Inherited Members
- Public Member Functions inherited from CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec
- Public Attributes inherited from CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec
int32_t visibility = -1
 The index of the accessor encoding the visibility of each triangle edge as a bitfield with two bits per edge.
int32_t material = -1
 The index of a glTF material with which the edges are to be drawn.
int32_t silhouetteNormals = -1
 The index of the accessor encoding the pair of outward-facing normals for the two faces sharing each silhouette edge (visibility 1) encoded in visibility.
std::vector< CesiumGltf::LineString > lineStrings
 An array of edges encoded as line strings.
- Static Public Attributes inherited from CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec
static constexpr const char * ExtensionName
- Protected Member Functions inherited from CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec
 ExtensionExtMeshPrimitiveEdgeVisibilitySpec ()=default
Definition at line 8 of file ExtensionExtMeshPrimitiveEdgeVisibility.h.
