Represents one or more line strings to be drawn as edges of a triangle mesh. More...
#include <CesiumGltf/LineString.h>
| int32_t | indices = -1 |
| The index of the accessor that contains the vertex indices for the line strings. | |
| int32_t | material = -1 |
| The index of a glTF material with which the edges are to be drawn. | |
| static constexpr const char * | TypeName = "LineString" |
Definition at line 15 of file LineString.h.
Definition at line 48 of file LineString.h.
| int32_t CesiumGltf::LineString::indices = -1 |
The index of the accessor that contains the vertex indices. The accessor MUST have SCALAR type and an unsigned integer component type. The indices are permitted to include the maximal index value for the component type, indicating the start of a new line string.
Definition at line 31 of file LineString.h.
| int32_t CesiumGltf::LineString::material = -1 |
If omitted, the edges are drawn using the same material as the edges encoded by the extension's visibility field, or else that of the triangle mesh primitive.
Definition at line 40 of file LineString.h.
Definition at line 20 of file LineString.h.
