CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibility::Visibility Struct Reference
Known values for the visibility specified for a single edge. More...
#include <CesiumGltf/ExtensionExtMeshPrimitiveEdgeVisibility.h>
static constexpr uint8_t HIDDEN = 0
 Hidden edge - the edge should never be drawn.
static constexpr uint8_t SILHOUETTE = 1
 Silhouette edge - the edge should be drawn only in silhouette (i.e., when separating a front-facing triangle from a back-facing triangle)
static constexpr uint8_t HARD_EDGE = 2
 Hard edge - the edge should always be drawn.
static constexpr uint8_t REPEATED_HARD_EDGE = 3
 Repeated hard edge - the edge should always be drawn, and its visibility is already encoded as HARD_EDGE for an adjoining triangle.
Definition at line 13 of file ExtensionExtMeshPrimitiveEdgeVisibility.h.
◆ HARD_EDGE
uint8_t CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibility::Visibility::HARD_EDGE = 2
Definition at line 23 of file ExtensionExtMeshPrimitiveEdgeVisibility.h.
◆ HIDDEN
uint8_t CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibility::Visibility::HIDDEN = 0
Definition at line 15 of file ExtensionExtMeshPrimitiveEdgeVisibility.h.
◆ REPEATED_HARD_EDGE
uint8_t CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibility::Visibility::REPEATED_HARD_EDGE = 3
Definition at line 27 of file ExtensionExtMeshPrimitiveEdgeVisibility.h.
◆ SILHOUETTE
uint8_t CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibility::Visibility::SILHOUETTE = 1
Definition at line 20 of file ExtensionExtMeshPrimitiveEdgeVisibility.h.
