glTF extension encoding the visibility of the edges of a triangles primitive More...
#include <CesiumGltf/ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h>
| int32_t | visibility = -1 |
| The index of the accessor encoding the visibility of each triangle edge as a bitfield with two bits per edge. | |
| int32_t | material = -1 |
| The index of a glTF material with which the edges are to be drawn. | |
| int32_t | silhouetteNormals = -1 |
The index of the accessor encoding the pair of outward-facing normals for the two faces sharing each silhouette edge (visibility 1) encoded in visibility. | |
| std::vector< CesiumGltf::LineString > | lineStrings |
| An array of edges encoded as line strings. | |
| static constexpr const char * | ExtensionName |
| ExtensionExtMeshPrimitiveEdgeVisibilitySpec ()=default | |
| This class is not meant to be instantiated directly. Use ExtensionExtMeshPrimitiveEdgeVisibility instead. | |
Friends | |
| struct | ExtensionExtMeshPrimitiveEdgeVisibility |
Definition at line 17 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
Definition at line 71 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
friend |
Definition at line 90 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
Definition at line 26 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
| std::vector<CesiumGltf::LineString> CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec::lineStrings |
Edges encoded as line strings MUST NOT also be encoded by the visibility property.
Definition at line 63 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
| int32_t CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec::material = -1 |
If omitted, the edges are drawn using the same material as the triangle mesh primitive.
Definition at line 45 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
| int32_t CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec::silhouetteNormals = -1 |
This property MUST be defined if and only if visibility encodes at least one edge with visibility value 1.
Definition at line 55 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
Definition at line 22 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
| int32_t CesiumGltf::ExtensionExtMeshPrimitiveEdgeVisibilitySpec::visibility = -1 |
An edge visibility of 0 indicates the edge is never drawn; 1 indicates the edge is only drawn in silhouette; 2 indicates a 'hard' (always-drawn) edge; and 3 indicates a repeated occurrence of a 'hard' edge.
Definition at line 37 of file ExtensionExtMeshPrimitiveEdgeVisibilitySpec.h.
