CesiumGltf::EnumSpec Struct Reference
An object defining the values of an enum. More...
#include <CesiumGltf/EnumSpec.h>
Inheritance diagram for CesiumGltf::EnumSpec:
CesiumUtility::ExtensibleObject CesiumGltf::Enum
Classes
struct  ValueType
 Known values for The type of the integer enum value. More...
 The name of the enum, e.g. for display purposes.
 The description of the enum.
std::string valueType = ValueType::UINT16
std::vector< CesiumGltf::EnumValue > values
 An array of enum values. Duplicate names or duplicate integer values are not allowed.
static constexpr const char * TypeName = "Enum"
Protected Member Functions
 EnumSpec ()=default
 This class is not meant to be instantiated directly. Use Enum instead.
Friends
struct Enum
Definition at line 17 of file EnumSpec.h.
int64_t CesiumGltf::EnumSpec::getSizeBytes ( ) const
Definition at line 82 of file EnumSpec.h.
◆ Enum
friend struct Enum
friend
Definition at line 106 of file EnumSpec.h.
◆ description
std::optional<std::string> CesiumGltf::EnumSpec::description
Definition at line 60 of file EnumSpec.h.
◆ name
std::optional<std::string> CesiumGltf::EnumSpec::name
Definition at line 55 of file EnumSpec.h.
const char* CesiumGltf::EnumSpec::TypeName = "Enum"
Definition at line 21 of file EnumSpec.h.
◆ values
std::vector<CesiumGltf::EnumValue> CesiumGltf::EnumSpec::values
Definition at line 74 of file EnumSpec.h.
◆ valueType
std::string CesiumGltf::EnumSpec::valueType = ValueType::UINT16
Known values are defined in ValueType.
Definition at line 68 of file EnumSpec.h.
