CesiumGltf::EnumValue Struct Referencefinal
An enum value. More...
#include <CesiumGltf/EnumValue.h>
Inheritance diagram for CesiumGltf::EnumValue:
std::string name
 The name of the enum value.
 The description of the enum value.
int64_t value = int64_t()
 The integer enum value.
static constexpr const char * TypeName = "EnumValue"
An enum value.
Definition at line 16 of file EnumValue.h.
int64_t CesiumGltf::EnumValue::getSizeBytes ( ) const
Definition at line 43 of file EnumValue.h.
◆ description
std::optional<std::string> CesiumGltf::EnumValue::description
Definition at line 30 of file EnumValue.h.
◆ name
std::string CesiumGltf::EnumValue::name
Definition at line 25 of file EnumValue.h.
const char* CesiumGltf::EnumValue::TypeName = "EnumValue"
Definition at line 20 of file EnumValue.h.
◆ value
int64_t CesiumGltf::EnumValue::value = int64_t()
Definition at line 35 of file EnumValue.h.
