EnumSpec.h
5#include <CesiumGltf/EnumValue.h>
9#include <optional>
10#include <string>
11#include <vector>
12
13namespace CesiumGltf {
17struct CESIUMGLTF_API EnumSpec : public CesiumUtility::ExtensibleObject {
21 static constexpr const char* TypeName = "Enum";
22
26 struct ValueType {
28 inline static const std::string INT8 = "INT8";
29
31 inline static const std::string UINT8 = "UINT8";
32
34 inline static const std::string INT16 = "INT16";
35
37 inline static const std::string UINT16 = "UINT16";
38
40 inline static const std::string INT32 = "INT32";
41
43 inline static const std::string UINT32 = "UINT32";
44
46 inline static const std::string INT64 = "INT64";
47
49 inline static const std::string UINT64 = "UINT64";
50 };
51
55 std::optional<std::string> name;
56
60 std::optional<std::string> description;
61
69
74 std::vector<CesiumGltf::EnumValue> values;
75
82 int64_t getSizeBytes() const {
83 int64_t accum = 0;
84 accum += int64_t(sizeof(EnumSpec));
86 int64_t(sizeof(CesiumUtility::ExtensibleObject));
87 if (this->name) {
88 accum += int64_t(this->name->capacity() * sizeof(char));
89 }
90 if (this->description) {
91 accum += int64_t(this->description->capacity() * sizeof(char));
92 }
93 accum += int64_t(sizeof(CesiumGltf::EnumValue) * this->values.capacity());
94 for (const CesiumGltf::EnumValue& value : this->values) {
95 accum += value.getSizeBytes() - int64_t(sizeof(CesiumGltf::EnumValue));
96 }
97 return accum;
98 }
99
100protected:
105 EnumSpec() = default;
106 friend struct Enum;
107};
108} // namespace CesiumGltf
Known values for The type of the integer enum value.
Definition EnumSpec.h:26
UINT8
Definition EnumSpec.h:31
INT16
Definition EnumSpec.h:34
INT64
Definition EnumSpec.h:46
INT32
Definition EnumSpec.h:40
UINT16
Definition EnumSpec.h:37
UINT32
Definition EnumSpec.h:43
UINT64
Definition EnumSpec.h:49
INT8
Definition EnumSpec.h:28
EnumSpec()=default
This class is not meant to be instantiated directly. Use Enum instead.
Definition EnumSpec.h:21
std::string valueType
Definition EnumSpec.h:68
Definition EnumSpec.h:82
The name of the enum, e.g. for display purposes.
Definition EnumSpec.h:55
The description of the enum.
Definition EnumSpec.h:60
std::vector< CesiumGltf::EnumValue > values
An array of enum values. Duplicate names or duplicate integer values are not allowed.
Definition EnumSpec.h:74
An enum value.
Definition EnumValue.h:16
