CesiumGltf::CameraOrthographic Struct Referencefinal
An orthographic camera containing properties to create an orthographic projection matrix. More...
#include <CesiumGltf/CameraOrthographic.h>
Inheritance diagram for CesiumGltf::CameraOrthographic:
double xmag = double()
 The floating-point horizontal magnification of the view. This value MUST NOT be equal to zero. This value SHOULD NOT be negative.
double ymag = double()
 The floating-point vertical magnification of the view. This value MUST NOT be equal to zero. This value SHOULD NOT be negative.
double zfar = double()
 The floating-point distance to the far clipping plane. This value MUST NOT be equal to zero. zfar MUST be greater than znear.
double znear = double()
 The floating-point distance to the near clipping plane.
static constexpr const char * TypeName = "CameraOrthographic"
Definition at line 13 of file CameraOrthographic.h.
int64_t CesiumGltf::CameraOrthographic::getSizeBytes ( ) const
Definition at line 49 of file CameraOrthographic.h.
const char* CesiumGltf::CameraOrthographic::TypeName = "CameraOrthographic"
Definition at line 18 of file CameraOrthographic.h.
◆ xmag
double CesiumGltf::CameraOrthographic::xmag = double()
Definition at line 24 of file CameraOrthographic.h.
◆ ymag
double CesiumGltf::CameraOrthographic::ymag = double()
Definition at line 30 of file CameraOrthographic.h.
◆ zfar
double CesiumGltf::CameraOrthographic::zfar = double()
Definition at line 36 of file CameraOrthographic.h.
◆ znear
double CesiumGltf::CameraOrthographic::znear = double()
Definition at line 41 of file CameraOrthographic.h.
