A perspective camera containing properties to create a perspective projection matrix. More...
#include <CesiumGltf/CameraPerspective.h>
| std::optional< double > | aspectRatio |
| The floating-point aspect ratio of the field of view. | |
| double | yfov = double() |
| The floating-point vertical field of view in radians. This value SHOULD be less than π. | |
| std::optional< double > | zfar |
| The floating-point distance to the far clipping plane. | |
| double | znear = double() |
| The floating-point distance to the near clipping plane. | |
| static constexpr const char * | TypeName = "CameraPerspective" |
Definition at line 15 of file CameraPerspective.h.
Definition at line 56 of file CameraPerspective.h.
| std::optional<double> CesiumGltf::CameraPerspective::aspectRatio |
When undefined, the aspect ratio of the rendering viewport MUST be used.
Definition at line 28 of file CameraPerspective.h.
Definition at line 20 of file CameraPerspective.h.
| double CesiumGltf::CameraPerspective::yfov = double() |
Definition at line 34 of file CameraPerspective.h.
| std::optional<double> CesiumGltf::CameraPerspective::zfar |
When defined, zfar MUST be greater than znear. If zfar is undefined, client implementations SHOULD use infinite projection matrix.
Definition at line 43 of file CameraPerspective.h.
| double CesiumGltf::CameraPerspective::znear = double() |
Definition at line 48 of file CameraPerspective.h.
