CesiumGltf::BufferView::Target Struct Reference
Known values for The hint representing the intended GPU buffer type to use with this buffer view. More...
#include <CesiumGltf/BufferView.h>
static constexpr int32_t ARRAY_BUFFER = 34962
 ARRAY_BUFFER (34962)
static constexpr int32_t ELEMENT_ARRAY_BUFFER = 34963
 ELEMENT_ARRAY_BUFFER (34963)
Definition at line 25 of file BufferView.h.
◆ ARRAY_BUFFER
int32_t CesiumGltf::BufferView::Target::ARRAY_BUFFER = 34962
Definition at line 27 of file BufferView.h.
◆ ELEMENT_ARRAY_BUFFER
int32_t CesiumGltf::BufferView::Target::ELEMENT_ARRAY_BUFFER = 34963
Definition at line 30 of file BufferView.h.
