An animation channel combines an animation sampler with a target property being animated. More...
#include <CesiumGltf/AnimationChannel.h>
| int32_t | sampler = -1 |
| The index of a sampler in this animation used to compute the value for the target. | |
| CesiumGltf::AnimationChannelTarget | target |
| The descriptor of the animated property. | |
| static constexpr const char * | TypeName = "AnimationChannel" |
Definition at line 16 of file AnimationChannel.h.
Definition at line 43 of file AnimationChannel.h.
| int32_t CesiumGltf::AnimationChannel::sampler = -1 |
The index of a sampler in this animation used to compute the value for the target, e.g., a node's translation, rotation, or scale (TRS).
Definition at line 30 of file AnimationChannel.h.
| CesiumGltf::AnimationChannelTarget CesiumGltf::AnimationChannel::target |
Definition at line 35 of file AnimationChannel.h.
Definition at line 21 of file AnimationChannel.h.
