An animation sampler combines timestamps with a sequence of output values and defines an interpolation algorithm. More...
#include <CesiumGltf/AnimationSampler.h>
Classes | |
| struct | Interpolation |
| Known values for Interpolation algorithm. More... | |
| int32_t | input = -1 |
| The index of an accessor containing keyframe timestamps. | |
| std::string | interpolation = Interpolation::LINEAR |
| Interpolation algorithm. | |
| int32_t | output = -1 |
| The index of an accessor, containing keyframe output values. | |
| static constexpr const char * | TypeName = "AnimationSampler" |
Definition at line 16 of file AnimationSampler.h.
Definition at line 75 of file AnimationSampler.h.
| int32_t CesiumGltf::AnimationSampler::input = -1 |
The accessor MUST be of scalar type with floating-point components. The values represent time in seconds with time[0] >= 0.0, and strictly increasing values, i.e., time[n + 1] > time[n].
Definition at line 54 of file AnimationSampler.h.
| std::string CesiumGltf::AnimationSampler::interpolation = Interpolation::LINEAR |
Known values are defined in Interpolation.
Definition at line 62 of file AnimationSampler.h.
| int32_t CesiumGltf::AnimationSampler::output = -1 |
Definition at line 67 of file AnimationSampler.h.
Definition at line 21 of file AnimationSampler.h.
