Cesium3DTiles::ConditionalContentItem Struct Referencefinal
Defines the structure of a single content item in 3DTILES_content_conditional. More...
#include <Cesium3DTiles/ConditionalContentItem.h>
Inheritance diagram for Cesium3DTiles::ConditionalContentItem:
Cesium3DTiles::Content CesiumUtility::ExtensibleObject
- Public Member Functions inherited from Cesium3DTiles::Content
std::unordered_map< std::string, CesiumUtility::JsonValue > keys
 Properties that define the conditions based on which the item can become active. The names of these properties correspond to the 'dimensions' that are defined in the top-level extension object.
- Public Attributes inherited from Cesium3DTiles::Content
std::optional< Cesium3DTiles::BoundingVolume > boundingVolume
 An optional bounding volume that tightly encloses tile content. tile.boundingVolume provides spatial coherence and tile.content.boundingVolume enables tight view frustum culling. When this is omitted, tile.boundingVolume is used.
std::string uri
 A uri that points to tile content. When the uri is relative, it is relative to the referring tileset JSON file.
std::optional< Cesium3DTiles::MetadataEntity > metadata
 Metadata that is associated with this content.
std::optional< int64_t > group
 The group this content belongs to. The value is an index into the array of groups that is defined for the containing tileset.
static constexpr const char * TypeName = "ConditionalContentItem"
- Static Public Attributes inherited from Cesium3DTiles::Content
static constexpr const char * TypeName = "Content"
Definition at line 17 of file ConditionalContentItem.h.
int64_t Cesium3DTiles::ConditionalContentItem::getSizeBytes ( ) const
Definition at line 36 of file ConditionalContentItem.h.
◆ keys
std::unordered_map<std::string, CesiumUtility::JsonValue> Cesium3DTiles::ConditionalContentItem::keys
Definition at line 28 of file ConditionalContentItem.h.
const char* Cesium3DTiles::ConditionalContentItem::TypeName = "ConditionalContentItem"
Definition at line 21 of file ConditionalContentItem.h.
