CesiumIonClient::Token Struct Reference
A Cesium ion access token. More...
#include <CesiumIonClient/Token.h>
std::string id {}
 The identifier of the token.
std::string name {}
 The name of the token.
std::string token {}
 The token value.
std::string dateAdded {}
 The date and time that this token was created, in RFC 3339 format.
std::string dateModified {}
 The date and time that this token was last modified, in RFC 3339 format.
std::string dateLastUsed {}
 The date and time that this token was last used, in RFC 3339 format.
std::optional< std::vector< int64_t > > assetIds {}
 The IDs of the assets that can be accessed using this token.
bool isDefault {}
 True if this is the default token.
std::optional< std::vector< std::string > > allowedUrls {}
 The URLs from which this token can be accessed.
std::vector< std::string > scopes {}
 The scopes granted by this token.
Definition at line 12 of file Token.h.
◆ allowedUrls
std::optional<std::vector<std::string> > CesiumIonClient::Token::allowedUrls {}
If std::nullopt, the token can be accessed from any URL.
Definition at line 61 of file Token.h.
◆ assetIds
std::optional<std::vector<int64_t> > CesiumIonClient::Token::assetIds {}
If std::nullopt, the token allows access to all assets.
Definition at line 49 of file Token.h.
◆ dateAdded
std::string CesiumIonClient::Token::dateAdded {}
Definition at line 31 of file Token.h.
◆ dateLastUsed
std::string CesiumIonClient::Token::dateLastUsed {}
Definition at line 42 of file Token.h.
◆ dateModified
std::string CesiumIonClient::Token::dateModified {}
Definition at line 37 of file Token.h.
◆ id
std::string CesiumIonClient::Token::id {}
Definition at line 16 of file Token.h.
◆ isDefault
bool CesiumIonClient::Token::isDefault {}
Definition at line 54 of file Token.h.
◆ name
std::string CesiumIonClient::Token::name {}
Definition at line 21 of file Token.h.
◆ scopes
std::vector<std::string> CesiumIonClient::Token::scopes {}
Definition at line 66 of file Token.h.
◆ token
std::string CesiumIonClient::Token::token {}
The token value.
Definition at line 26 of file Token.h.
