CesiumIonClient::Response< T > Struct Template Referencefinal
A response from Cesium ion. More...
#include <CesiumIonClient/Response.h>
 Response ()
 Creates a new empty Response.
 Response (const std::shared_ptr< CesiumAsync::IAssetRequest > &pRequest, T &&value)
 Creates a Response from a completed request and a response value.
 Response (T &&value, uint16_t httpStatusCode, const std::string &errorCode, const std::string &errorMessage)
 Creates a Response from a response value, status code, and error information.
 Response (uint16_t httpStatusCode, const std::string &errorCode, const std::string &errorMessage)
 Creates a Response with no value, a status code, and error information.
std::optional< T > value
 The response value, or std::nullopt if the response was unsuccessful.
 The HTTP status code returned by Cesium ion.
std::string errorCode
 The error code, or empty string if there was no error.
std::string errorMessage
 The error message returned, or an empty string if there was no error.
std::optional< std::string > nextPageUrl
 The URL to use to obtain the next page of results, if there is a next page.
std::optional< std::string > previousPageUrl
 The URL to use to obtain the previous page of results, if there is one.
struct CesiumIonClient::Response< T >
Template Parameters
TThe type of the response object.
Definition at line 19 of file Response.h.
◆ Response() [1/3]
CesiumIonClient::Response< T >::Response ( const std::shared_ptr< CesiumAsync::IAssetRequest > & pRequest,
T && value )
pRequestA completed request. The constructor will attempt to obtain the httpStatusCode, previousPageUrl, and nextPageUrl from this request.
valueThe response value.
◆ Response() [2/3]
CesiumIonClient::Response< T >::Response ( T && value,
const std::string & errorCode,
const std::string & errorMessage )
httpStatusCodeThe HTTP status code of the response.
errorCodeThe error code. See Response::errorCode. If no error occurred, pass an empty string.
errorMessageThe error message. See Response::errorMessage. If no error occurred, pass an empty string.
◆ Response() [3/3]
CesiumIonClient::Response< T >::Response ( uint16_t httpStatusCode,
◆ errorCode
std::string CesiumIonClient::Response< T >::errorCode
If no response is received at all, the code will be "NoResponse".
If Cesium ion returns an error, this will be the code reported by Cesium ion.
If Cesium ion reports success but an error occurs while attempting to parse the response, the code will be "ParseError".
Definition at line 90 of file Response.h.
◆ errorMessage
std::string CesiumIonClient::Response< T >::errorMessage
If Cesium ion returns an error, this will be the message reported by Cesium ion. If Cesium ion reports success but another error occurs, the message will contain further details of the error.
Definition at line 100 of file Response.h.
◆ httpStatusCode
uint16_t CesiumIonClient::Response< T >::httpStatusCode
Definition at line 76 of file Response.h.
◆ nextPageUrl
std::optional<std::string> CesiumIonClient::Response< T >::nextPageUrl
Call Connection::nextPage rather than using this field directly.
Definition at line 108 of file Response.h.
◆ previousPageUrl
std::optional<std::string> CesiumIonClient::Response< T >::previousPageUrl
Call Connection::previousPage rather than using this field directly.
Definition at line 116 of file Response.h.
◆ value
std::optional<T> CesiumIonClient::Response< T >::value
Definition at line 71 of file Response.h.
