CesiumIonClient::QuickAddAsset Struct Reference
A quick add asset. More...
#include <CesiumIonClient/Defaults.h>
std::string name {}
 The name of this asset.
std::string objectName {}
 The name of the main asset. In most cases this will be the same as name, but in the cases of assets with raster overlays, this will be the non-imagery asset.
std::string description {}
 A Markdown compatible string describing this asset.
int64_t assetId = -1
 The unique identifier for this asset.
std::string type {}
 This asset's type.
bool subscribed = false
 true if the user is subscribed to the asset, false otherwise.
std::vector< QuickAddRasterOverlay > rasterOverlays {}
 The raster overlays available for this asset.
A quick add asset.
Definition at line 52 of file Defaults.h.
◆ assetId
int64_t CesiumIonClient::QuickAddAsset::assetId = -1
Definition at line 73 of file Defaults.h.
◆ description
std::string CesiumIonClient::QuickAddAsset::description {}
Definition at line 68 of file Defaults.h.
◆ name
std::string CesiumIonClient::QuickAddAsset::name {}
Definition at line 56 of file Defaults.h.
◆ objectName
std::string CesiumIonClient::QuickAddAsset::objectName {}
Definition at line 63 of file Defaults.h.
◆ rasterOverlays
std::vector<QuickAddRasterOverlay> CesiumIonClient::QuickAddAsset::rasterOverlays {}
Definition at line 91 of file Defaults.h.
◆ subscribed
bool CesiumIonClient::QuickAddAsset::subscribed = false
Definition at line 86 of file Defaults.h.
◆ type
std::string CesiumIonClient::QuickAddAsset::type {}
This asset's type.
Valid values are: 3DTILES, GLTF, IMAGERY, TERRAIN, KML, CZML, GEOJSON.
Definition at line 81 of file Defaults.h.
