CesiumIonClient::ListTokensOptions Struct Reference
Options to be passed to Connection::tokens. More...
#include <CesiumIonClient/Connection.h>
std::optional< int32_t > limit
 The maximum number of tokens to return in a single page.
std::optional< int32_t > page
 The page number, where the first page of results is page 1 (not 0).
std::optional< std::string > search
 One or more keywords separated by whitespace by which to filter the list of tokens. The token name will contain each keyword of the search string.
std::optional< std::string > sortBy
 The property by which to sort results. Valid values are "NAME" and "LAST_USED".
std::optional< SortOrder > sortOrder
Definition at line 34 of file Connection.h.
◆ limit
std::optional<int32_t> CesiumIonClient::ListTokensOptions::limit
Receiving fewer tokens should not be interpreted as the end of the collection. The end of the collection is reached when the response does not contain Response::nextPageUrl.
Definition at line 42 of file Connection.h.
◆ page
std::optional<int32_t> CesiumIonClient::ListTokensOptions::page
Definition at line 47 of file Connection.h.
◆ search
std::optional<std::string> CesiumIonClient::ListTokensOptions::search
Definition at line 54 of file Connection.h.
◆ sortBy
std::optional<std::string> CesiumIonClient::ListTokensOptions::sortBy
Definition at line 60 of file Connection.h.
◆ sortOrder
std::optional<SortOrder> CesiumIonClient::ListTokensOptions::sortOrder
Definition at line 66 of file Connection.h.
