CesiumIonClient::Connection Class Reference
A connection to Cesium ion that can be used to interact with it via its REST API. More...
#include <CesiumIonClient/Connection.h>
 Connection (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &accessToken, const CesiumIonClient::ApplicationData &appData, const std::string &apiUrl="https://api.cesium.com")
 Creates a connection to Cesium ion using the provided access token.
 Connection (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const CesiumIonClient::LoginToken &accessToken, const std::string &refreshToken, int64_t clientId, const std::string &redirectPath, const CesiumIonClient::ApplicationData &appData, const std::string &apiUrl="https://api.cesium.com")
 Creates a "login" connection to Cesium ion.
 Connection (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const CesiumIonClient::ApplicationData &appData, const std::string &apiUrl)
 Creates a connection to a Cesium ion server without authentication.
const CesiumAsync::AsyncSystem & getAsyncSystem () const noexcept
 Gets the async system used by this connection to do work in threads.
const std::shared_ptr< CesiumAsync::IAssetAccessor > & getAssetAccessor () const noexcept
 Gets the interface used by this connection to interact with the Cesium ion REST API.
const std::string & getAccessToken () const noexcept
 Gets the access token used by this connection.
const std::string & getRefreshToken () const noexcept
 Gets the refresh token used by this connection.
const std::string & getApiUrl () const noexcept
 Gets the Cesium ion API base URL.
CesiumAsync::Future< Response< Profile > > me () const
 Retrieves profile information for the access token currently being used to make API calls.
CesiumAsync::Future< Response< Defaults > > defaults () const
 Retrieves default imagery, terrain and building assets along with quick add assets that can be useful to use within other applications.
CesiumAsync::Future< Response< Assets > > assets () const
 Gets the list of available assets.
CesiumAsync::Future< Response< TokenList > > tokens (const ListTokensOptions &options={}) const
 Invokes the "List tokens" service to get the list of available tokens.
CesiumAsync::Future< Response< Asset > > asset (int64_t assetID) const
 Gets details of the asset with the given ID.
CesiumAsync::Future< Response< Token > > token (const std::string &tokenID) const
 Gets details of the token with the given ID.
CesiumAsync::Future< Response< TokenList > > nextPage (const Response< TokenList > &currentPage) const
 Gets the next page of results from the "List tokens" service.
CesiumAsync::Future< Response< TokenList > > previousPage (const Response< TokenList > &currentPage) const
 Gets the previous page of results from the "List tokens" service.
CesiumAsync::Future< Response< Token > > createToken (const std::string &name, const std::vector< std::string > &scopes, const std::optional< std::vector< int64_t > > &assetIds=std::nullopt, const std::optional< std::vector< std::string > > &allowedUrls=std::nullopt) const
 Creates a new token.
CesiumAsync::Future< Response< NoValue > > modifyToken (const std::string &tokenID, const std::string &newName, const std::optional< std::vector< int64_t > > &newAssetIDs, const std::vector< std::string > &newScopes, const std::optional< std::vector< std::string > > &newAllowedUrls) const
 Modifies a token.
CesiumAsync::Future< Response< GeocoderResult > > geocode (GeocoderProviderType provider, GeocoderRequestType type, const std::string &query) const
 Makes a request to the ion geocoding service.
static CesiumAsync::Future< CesiumUtility::Result< Connection > > authorize (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &friendlyApplicationName, int64_t clientID, const std::string &redirectPath, const std::vector< std::string > &scopes, std::function< void(const std::string &)> &&openUrlCallback, const CesiumIonClient::ApplicationData &appData, const std::string &ionApiUrl="https://api.cesium.com/", const std::string &ionAuthorizeUrl="https://ion.cesium.com/oauth")
 Authorizes access to Cesium ion on behalf of a user, and returns a Connection that can be used to interact with ion.
static CesiumAsync::Future< Response< ApplicationData > > appData (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &apiUrl="https://api.cesium.com")
 Retrieves information about the ion API server.
static CesiumAsync::Future< std::optional< std::string > > getApiUrl (const CesiumAsync::AsyncSystem &asyncSystem, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &ionUrl)
 Attempts to retrieve the ion endpoint URL by looking for a config.json file on the server.
static std::optional< std::string > getIdFromToken (const std::string &token)
 Decodes a token ID from a token.
Definition at line 73 of file Connection.h.
◆ Connection() [1/3]
CesiumIonClient::Connection::Connection ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::shared_ptr< CesiumAsync::IAssetAccessor > & pAssetAccessor,
const std::string & accessToken,
const CesiumIonClient::ApplicationData & appData,
const std::string & apiUrl = "https://api.cesium.com" )
This connection will not have the ability to refresh itself if the access token is invalid. This constructor is intended to be used with tokens that do not expire, rather than the Cesium ion OAuth2 login tokens.
asyncSystemThe async system used to do work in threads.
pAssetAccessorThe interface used to interact with the Cesium ion REST API.
accessTokenThe access token.
appDataThe app data retrieved from the Cesium ion server.
apiUrlThe base URL of the Cesium ion API.
◆ Connection() [2/3]
const CesiumIonClient::LoginToken & accessToken,
const std::string & refreshToken,
int64_t clientId,
const std::string & redirectPath,
This type of connection is usually initiated with a call to authorize. The parameters of the resulting connection can then be saved in a safe location, and the authorized login can be resumed later by passing them to this constructor.
refreshTokenThe refresh token.
clientIdThe OAuth2 client ID used to authorize the token for this connection. This will be used to refresh the token when it nears expiration.
redirectPathThe OAuth2 redirect path used to authorize this token for this connection. This will be used to refresh the token when it nears expiration.
◆ Connection() [3/3]
const std::string & apiUrl )
This is intended to be used with Cesium ion Self-Hosted instances that are set to Single User authentication.
◆ appData()
static CesiumAsync::Future< Response< ApplicationData > > CesiumIonClient::Connection::appData ( const CesiumAsync::AsyncSystem & asyncSystem,
static
apiUrlThe URL of the ion REST API to make requests against.
A future that resolves to the application information.
◆ asset()
CesiumAsync::Future< Response< Asset > > CesiumIonClient::Connection::asset ( int64_t assetID) const
assetIDThe asset ID.
A future that resolves to the asset details.
◆ assets()
CesiumAsync::Future< Response< Assets > > CesiumIonClient::Connection::assets ( ) const
A future that resolves to the asset information.
◆ authorize()
static CesiumAsync::Future< CesiumUtility::Result< Connection > > CesiumIonClient::Connection::authorize ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::string & friendlyApplicationName,
int64_t clientID,
const std::vector< std::string > & scopes,
std::function< void(const std::string &)> && openUrlCallback,
const std::string & ionApiUrl = "https://api.cesium.com/",
const std::string & ionAuthorizeUrl = "https://ion.cesium.com/oauth" )
static
Uses the "Authorization Code with PKCE" OAuth2 flow.
See Connecting to Cesium ion with OAuth2 for a description of the authorization process.
friendlyApplicationNameA friendly name for the application requesting access. It will be displayed to the user when authorization is complete, informing them that they can return to the original application.
clientIDThe client ID that was assigned to your application when you registered it.
redirectPathThe path on http://127.0.0.1 that a user will be redirected to once they authorize your application. This must match the URI provided when you registered your application, without the protocol, hostname, or port.
scopesThe list of scopes that the eventually-granted token should allow access to.
openUrlCallbackA function that is invoked to launch the user's web browser with a given URL so that they can authorize access.
ionApiUrlThe base URL of the Cesium ion API.
ionAuthorizeUrlThe URL of the Cesium ion OAuth authorization page.
A future that resolves to a Cesium ion Connection once the user authorizes the application and the token handshake completes. If the authorization fails, the CesiumUtility::Result::value will be std::nullopt, and CesiumUtility::Result::errors will contain details about the failure.
◆ createToken()
CesiumAsync::Future< Response< Token > > CesiumIonClient::Connection::createToken ( const std::string & name,
const std::optional< std::vector< int64_t > > & assetIds = std::nullopt,
const std::optional< std::vector< std::string > > & allowedUrls = std::nullopt ) const
nameThe name of the new token.
scopesThe scopes allowed by this token.
assetIdsThe assets that may be accessed by this token. If std::nullopt, access to all assets is allowed.
allowedUrlsThe URLs from which this token can be accessed. If std::nullopt, the token can be accessed from any URL.
The new token.
◆ defaults()
CesiumAsync::Future< Response< Defaults > > CesiumIonClient::Connection::defaults ( ) const
This route will always return data, but will return user specific information with any valid token.
A future that resolves to the default information.
◆ geocode()
CesiumAsync::Future< Response< GeocoderResult > > CesiumIonClient::Connection::geocode ( GeocoderProviderType provider,
const std::string & query ) const
A geocoding service is used to make a plain text query (like an address, city name, or landmark) and obtain information about where it's located.
providerThe ion geocoding provider to use.
typeThe type of request to make. See GeocoderRequestType for more information.
queryThe query to make.
◆ getApiUrl()
static CesiumAsync::Future< std::optional< std::string > > CesiumIonClient::Connection::getApiUrl ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::string & ionUrl )
static
This config file isn't present on ion.cesium.com, but will be present on Cesium ion self-hosted instances to allow the user to configure the URLs of their self-hosted instance as needed.
ionUrlThe URL of the Cesium ion instance to make this request against.
The Cesium ion REST API url for this ion instance, or std::nullopt if none found.
◆ getIdFromToken()
static std::optional< std::string > CesiumIonClient::Connection::getIdFromToken ( const std::string & token)
static
tokenThe token to decode.
The token ID, or std::nullopt if the token ID cannot be determined from the token.
◆ me()
CesiumAsync::Future< Response< Profile > > CesiumIonClient::Connection::me ( ) const
This route works with any valid token, but additional information is returned if the token uses the profile:read scope.
A future that resolves to the profile information.
◆ modifyToken()
CesiumAsync::Future< Response< NoValue > > CesiumIonClient::Connection::modifyToken ( const std::string & tokenID,
const std::string & newName,
const std::optional< std::vector< int64_t > > & newAssetIDs,
const std::vector< std::string > & newScopes,
const std::optional< std::vector< std::string > > & newAllowedUrls ) const
Modifies a token.
tokenIDThe ID of the token to modify.
newNameThe new name of the token.
newAssetIDsThe assets that may be accessed by this token. If std::nullopt, access to all assets is allowed.
newScopesThe new OAuth scopes allowed by this token.
newAllowedUrlsThe new URLs from which this token can be accessed. If std::nullopt, the token can be accessed from any URL.
A value-less response. If the response is successful, the token has been modified.
◆ nextPage()
CesiumAsync::Future< Response< TokenList > > CesiumIonClient::Connection::nextPage ( const Response< TokenList > & currentPage) const
To get the first page, use Connection::tokens.
currentPageThe current page from which to get the next page.
A future that resolves to the next page of tokens, or to a response with an Response::errorCode of "NoMorePages" if the currentPage is the last one.
◆ previousPage()
CesiumAsync::Future< Response< TokenList > > CesiumIonClient::Connection::previousPage ( const Response< TokenList > & currentPage) const
To get the first page (or a particular page), use Connection::tokens.
currentPageThe current page from which to get the previous page.
A future that resolves to the previous page of tokens, or to a response with an Response::errorCode of "NoMorePages" if the currentPage is the first one.
◆ token()
CesiumAsync::Future< Response< Token > > CesiumIonClient::Connection::token ( const std::string & tokenID) const
tokenIDThe token ID.
A future that resolves to the token details.
◆ tokens()
CesiumAsync::Future< Response< TokenList > > CesiumIonClient::Connection::tokens ( const ListTokensOptions & options = {}) const
Only a single page is returned. To obtain additional pages, use Connection::nextPage and Connection::previousPage.
optionsOptions to include in the "List tokens" request.
A future that resolves to a page of token information.
