CesiumVectorOverlays::VectorTilesRasterOverlay Class Referencefinal
A raster overlay made from rasterizing a vector tiles tileset. More...
#include <CesiumVectorOverlays/VectorTilesRasterOverlay.h>
Inheritance diagram for CesiumVectorOverlays::VectorTilesRasterOverlay:
CesiumRasterOverlays::RasterOverlay CesiumUtility::ReferenceCounted< T, false >
 VectorTilesRasterOverlay (const std::string &name, const std::string &url, const VectorTilesRasterOverlayOptions &vectorOptions={}, const CesiumRasterOverlays::RasterOverlayOptions &overlayOptions={})
 Creates a new VectorTilesRasterOverlay from a URL.
 VectorTilesRasterOverlay (const std::string &name, int64_t ionAssetID, const std::string &ionAccessToken, const std::string &ionAssetEndpointUrl="https://api.cesium.com/", const VectorTilesRasterOverlayOptions &vectorOptions={}, const CesiumRasterOverlays::RasterOverlayOptions &overlayOptions={})
 Creates a new VectorTilesRasterOverlay from a Cesium ion asset.
virtual CesiumAsync::Future< CreateTileProviderResult > createTileProvider (const CesiumRasterOverlays::CreateRasterOverlayTileProviderParameters &parameters) const override
 Begins asynchronous creation of a tile provider for this overlay and eventually returns it via a Future.
- Public Member Functions inherited from CesiumRasterOverlays::RasterOverlay
 RasterOverlay (const std::string &name, const RasterOverlayOptions &overlayOptions=RasterOverlayOptions())
 Creates a new instance.
CesiumAsync::SharedFuture< void > & getAsyncDestructionCompleteEvent (const CesiumAsync::AsyncSystem &asyncSystem)
 A future that resolves when this RasterOverlay has been destroyed (i.e. its destructor has been called) and all async operations that it was executing have completed.
const std::string & getName () const noexcept
 Gets the name of this overlay.
RasterOverlayOptions & getOptions () noexcept
 Gets options for this overlay.
const RasterOverlayOptions & getOptions () const noexcept
CesiumUtility::IntrusivePointer< ActivatedRasterOverlay > activate (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Activates this overlay.
CesiumUtility::IntrusivePointer< RasterOverlayTileProvider > createPlaceholder (const RasterOverlayExternals &externals, const CesiumGeospatial::Ellipsoid &ellipsoid=CesiumGeospatial::Ellipsoid::WGS84) const
 Create a placeholder tile provider can be used in place of the real one while createTileProvider completes asynchronously.
void addReference () const
Additional Inherited Members
- Public Types inherited from CesiumRasterOverlays::RasterOverlay
using CreateTileProviderResult
 A result from a call to createTileProvider. This is expected to be an IntrusivePointer to a RasterOverlayTileProvider, but may be a RasterOverlayLoadFailureDetails if creating the tile provider wasn't successful.
Definition at line 35 of file VectorTilesRasterOverlay.h.
◆ VectorTilesRasterOverlay() [1/2]
CesiumVectorOverlays::VectorTilesRasterOverlay::VectorTilesRasterOverlay ( const std::string & name,
const std::string & url,
const VectorTilesRasterOverlayOptions & vectorOptions = {},
const CesiumRasterOverlays::RasterOverlayOptions & overlayOptions = {} )
nameThe user-given name of this layer.
urlThe URL of the tileset to load.
vectorOptionsOptions to configure this VectorTilesRasterOverlay.
overlayOptionsOptions to use for this RasterOverlay.
◆ VectorTilesRasterOverlay() [2/2]
int64_t ionAssetID,
const std::string & ionAccessToken,
const std::string & ionAssetEndpointUrl = "https://api.cesium.com/",
ionAssetIDThe ion asset ID of the tileset.
ionAccessTokenThe ion access token to use to access the tileset.
ionAssetEndpointUrlThe ion asset endpoint URL to use to access the tileset.
◆ createTileProvider()
virtual CesiumAsync::Future< CreateTileProviderResult > CesiumVectorOverlays::VectorTilesRasterOverlay::createTileProvider ( const CesiumRasterOverlays::CreateRasterOverlayTileProviderParameters & parameters) const
overridevirtual
parametersThe parameters for creating the tile provider.
The future that resolves to the tile provider when it is ready, or to error details in the case of an error.
Implements CesiumRasterOverlays::RasterOverlay.
