CesiumGltf::PropertyTableView Class Reference
Utility to retrieve the data of PropertyTable. More...
#include <CesiumGltf/PropertyTableView.h>
 PropertyTableView (const Model &model, const PropertyTable &propertyTable)
 Creates an instance of PropertyTableView.
PropertyTableViewStatus status () const noexcept
 Gets the status of this property table view.
const std::optional< std::string > & name () const noexcept
 Gets the name of the property table being viewed. Returns std::nullopt if no name was specified.
int64_t size () const noexcept
 Get the number of elements in this PropertyTableView. If the view is valid, this returns PropertyTable::count. Otherwise, this returns 0.
const Class * getClass () const noexcept
 Gets the Class that this property table conforms to.
const ClassProperty * getClassProperty (const std::string &propertyId) const
 Finds the ClassProperty that describes the type information of the property with the specified id.
template<typename T, bool Normalized = false>
PropertyTablePropertyView< T, Normalized > getPropertyView (const std::string &propertyId) const
 Gets a PropertyTablePropertyView that views the data of a property stored in the PropertyTable.
template<typename Callback>
void getPropertyView (const std::string &propertyId, Callback &&callback) const
 Gets a PropertyTablePropertyView through a callback that accepts a property id and a PropertyTablePropertyView that views the data of the property with the specified id.
void forEachProperty (Callback &&callback) const
 Iterates over each property in the PropertyTable with a callback that accepts a property id and a PropertyTablePropertyView to view the data stored in the PropertyTableProperty.
This should be used to get a PropertyTablePropertyView of a property in the property table. It will validate the EXT_structural_metadata format and ensure PropertyTablePropertyView does not access out of bounds.
Definition at line 55 of file PropertyTableView.h.
◆ PropertyTableView()
CesiumGltf::PropertyTableView::PropertyTableView ( const Model & model,
const PropertyTable & propertyTable )
modelThe glTF Model that contains the property table data.
propertyTableThe PropertyTable from which the view will retrieve data.
◆ forEachProperty()
void CesiumGltf::PropertyTableView::forEachProperty ( Callback && callback) const
This method will validate the EXT_structural_metadata format to ensure PropertyTablePropertyView retrieves the correct data. T must be one of the following: a scalar (uint8_t, int8_t, uint16_t, int16_t, uint32_t, int32_t, uint64_t, int64_t, float, double), a glm vecN composed of one of the scalar types, a glm matN composed of one of the scalar types, bool, std::string_view, or PropertyArrayView with T as one of the aforementioned types.
If the property is invalid, an empty PropertyTablePropertyView with an error status code will be passed to the callback. Otherwise, a valid property view will be passed to the callback.
callbackA callback function that accepts property id and PropertyTablePropertyView
Template Parameters
CallbackThe type of the callback function.
Definition at line 363 of file PropertyTableView.h.
◆ getClass()
const Class * CesiumGltf::PropertyTableView::getClass ( ) const
inlinenoexcept
A pointer to the Class. Returns nullptr if the PropertyTable did not specify a valid class.
Definition at line 101 of file PropertyTableView.h.
◆ getClassProperty()
const ClassProperty * CesiumGltf::PropertyTableView::getClassProperty ( const std::string & propertyId) const
propertyIdThe id of the property to retrieve the class for.
A pointer to the ClassProperty. Returns nullptr if the PropertyTableView is invalid or if no class property was found.
◆ getPropertyView() [1/2]
PropertyTablePropertyView< T, Normalized > CesiumGltf::PropertyTableView::getPropertyView ( const std::string & propertyId) const
If T does not match the type specified by the class property, this returns an invalid PropertyTablePropertyView. Likewise, if the value of Normalized does not match the value of ClassProperty::normalized for that class property, this returns an invalid property view. Only types with integer components may be normalized.
Template Parameters
TThe C++ type corresponding to the type of the data retrieved.
NormalizedWhether the property is normalized. Only applicable to types with integer components.
propertyIdThe id of the property to retrieve data from
A PropertyTablePropertyView of the property. If no valid property is found, the property view will be invalid.
Definition at line 140 of file PropertyTableView.h.
◆ getPropertyView() [2/2]
void CesiumGltf::PropertyTableView::getPropertyView ( const std::string & propertyId,
Callback && callback ) const
If the property is invalid, an empty PropertyTablePropertyView with an error status will be passed to the callback. Otherwise, a valid property view will be passed to the callback.
callbackA callback function that accepts a property id and a PropertyTablePropertyView
Template Parameters
Definition at line 179 of file PropertyTableView.h.
◆ name()
const std::optional< std::string > & CesiumGltf::PropertyTableView::name ( ) const
inlinenoexcept
Definition at line 79 of file PropertyTableView.h.
◆ size()
int64_t CesiumGltf::PropertyTableView::size ( ) const
inlinenoexcept
The number of elements in this PropertyTableView.
Definition at line 90 of file PropertyTableView.h.
◆ status()
PropertyTableViewStatus CesiumGltf::PropertyTableView::status ( ) const
inlinenoexcept
Indicates whether the view accurately reflects the property table's data, or whether an error occurred.
The status of this property table view.
Definition at line 73 of file PropertyTableView.h.
