Indicates the status of a property table property view. More...
#include <CesiumGltf/PropertyTablePropertyView.h>
| static const PropertyViewStatusType | ErrorInvalidPropertyTable = 14 |
| This property view was initialized from an invalid PropertyTable. | |
| static const PropertyViewStatusType | ErrorInvalidValueBufferView = 15 |
| This property view does not have a valid value buffer view index. | |
| static const PropertyViewStatusType | ErrorInvalidArrayOffsetBufferView = 16 |
| This array property view does not have a valid array offset buffer view index. | |
| static const PropertyViewStatusType | ErrorInvalidStringOffsetBufferView = 17 |
| This string property view does not have a valid string offset buffer view index. | |
| static const PropertyViewStatusType | ErrorInvalidValueBuffer = 18 |
| This property view has a valid value buffer view, but the buffer view specifies an invalid buffer index. | |
| static const PropertyViewStatusType | ErrorInvalidArrayOffsetBuffer = 19 |
| This property view has a valid array string buffer view, but the buffer view specifies an invalid buffer index. | |
| static const PropertyViewStatusType | ErrorInvalidStringOffsetBuffer = 20 |
| This property view has a valid string offset buffer view, but the buffer view specifies an invalid buffer index. | |
| static const PropertyViewStatusType | ErrorBufferViewOutOfBounds = 21 |
| This property view has a buffer view that points outside the bounds of its target buffer. | |
| static const PropertyViewStatusType | ErrorBufferViewSizeNotDivisibleByTypeSize = 22 |
| This property view has an invalid buffer view; its length is not a multiple of the size of its type / offset type. | |
| static const PropertyViewStatusType | ErrorBufferViewSizeDoesNotMatchPropertyTableCount = 23 |
| This property view has an invalid buffer view; its length does not match the size of the property table. | |
| static const PropertyViewStatusType | ErrorArrayCountAndOffsetBufferCoexist |
| This array property view has both a fixed length and an offset buffer view defined. | |
| static const PropertyViewStatusType | ErrorArrayCountAndOffsetBufferDontExist |
| This array property view has neither a fixed length nor an offset buffer view defined. | |
| static const PropertyViewStatusType | ErrorInvalidArrayOffsetType = 26 |
| This property view has an unknown array offset type. | |
| static const PropertyViewStatusType | ErrorInvalidStringOffsetType = 27 |
| This property view has an unknown string offset type. | |
| static const PropertyViewStatusType | ErrorArrayOffsetsNotSorted = 28 |
| This property view's array offset values are not sorted in ascending order. | |
| static const PropertyViewStatusType | ErrorStringOffsetsNotSorted = 29 |
| This property view's string offset values are not sorted in ascending order. | |
| static const PropertyViewStatusType | ErrorArrayOffsetOutOfBounds = 30 |
| This property view has an array offset that is out of bounds. | |
| static const PropertyViewStatusType | ErrorStringOffsetOutOfBounds = 31 |
| This property view has a string offset that is out of bounds. | |
Static Public Attributes inherited from CesiumGltf::PropertyViewStatus | |
| static const PropertyViewStatusType | Valid = 0 |
| This property view is valid and ready to use. | |
| static const PropertyViewStatusType | EmptyPropertyWithDefault = 1 |
| This property view does not contain any data, but specifies a default value. This happens when a class property is defined with a default value and omitted from an instance of the class's collective properties. In this case, it is not possible to retrieve the raw data from a property, but its default value will be accessible. | |
| static const PropertyViewStatusType | ErrorNonexistentProperty = 2 |
| This property view is trying to view a property that does not exist. | |
| static const PropertyViewStatusType | ErrorTypeMismatch = 3 |
| This property view's type does not match what is specified in ClassProperty::type. | |
| static const PropertyViewStatusType | ErrorComponentTypeMismatch = 4 |
| This property view's component type does not match what is specified in ClassProperty::componentType. | |
| static const PropertyViewStatusType | ErrorArrayTypeMismatch = 5 |
| This property view differs from what is specified in ClassProperty::array. | |
| static const PropertyViewStatusType | ErrorInvalidNormalization = 6 |
| This property says it is normalized, but it does not have an integer component type. | |
| static const PropertyViewStatusType | ErrorNormalizationMismatch = 7 |
| This property view's normalization differs from what is specified in ClassProperty::normalized. | |
| static const PropertyViewStatusType | ErrorInvalidOffset = 8 |
| The property provided an invalid offset value. | |
| static const PropertyViewStatusType | ErrorInvalidScale = 9 |
| The property provided an invalid scale value. | |
| static const PropertyViewStatusType | ErrorInvalidMax = 10 |
| The property provided an invalid maximum value. | |
| static const PropertyViewStatusType | ErrorInvalidMin = 11 |
| The property provided an invalid minimum value. | |
| static const PropertyViewStatusType | ErrorInvalidNoDataValue = 12 |
| The property provided an invalid "no data" value. | |
| static const PropertyViewStatusType | ErrorInvalidDefaultValue = 13 |
| The property provided an invalid default value. | |
| static const PropertyViewStatusType | ErrorInvalidEnum = 14 |
| The property provided an invalid enum value. | |
The PropertyTablePropertyView constructor always completes successfully. However, it may not always reflect the actual content of the PropertyTableProperty, but instead indicate that its size is 0. This enumeration provides the reason.
Definition at line 24 of file PropertyTablePropertyView.h.
static |
Definition at line 91 of file PropertyTablePropertyView.h.
static |
Definition at line 98 of file PropertyTablePropertyView.h.
static |
Definition at line 126 of file PropertyTablePropertyView.h.
static |
Definition at line 115 of file PropertyTablePropertyView.h.
static |
Definition at line 71 of file PropertyTablePropertyView.h.
static |
Definition at line 85 of file PropertyTablePropertyView.h.
static |
Definition at line 78 of file PropertyTablePropertyView.h.
static |
Definition at line 59 of file PropertyTablePropertyView.h.
static |
Definition at line 41 of file PropertyTablePropertyView.h.
static |
Definition at line 104 of file PropertyTablePropertyView.h.
static |
Definition at line 30 of file PropertyTablePropertyView.h.
static |
Definition at line 65 of file PropertyTablePropertyView.h.
static |
Definition at line 47 of file PropertyTablePropertyView.h.
static |
Definition at line 109 of file PropertyTablePropertyView.h.
static |
Definition at line 53 of file PropertyTablePropertyView.h.
static |
Definition at line 35 of file PropertyTablePropertyView.h.
static |
Definition at line 131 of file PropertyTablePropertyView.h.
static |
Definition at line 121 of file PropertyTablePropertyView.h.
