A depot for CesiumUtility::SharedAsset instances, which are potentially shared between multiple objects. More...
#include <CesiumAsync/SharedAssetDepot.h>
Public Types | |
| using | FactorySignature |
Signature for the callback function that will be called to fetch and create a new instance of TAssetType if one with the given key doesn't already exist in the depot. | |
| SharedAssetDepot (std::function< FactorySignature > factory) | |
Creates a new SharedAssetDepot using the given factory callback to load new assets. | |
| SharedFuture< CesiumUtility::ResultPointer< TAssetType > > | getOrCreate (const TContext &context, const TAssetKey &assetKey) |
| Gets an asset from the depot if it already exists, or creates it using the depot's factory if it does not. | |
| bool | invalidate (const TAssetKey &assetKey) |
| Invalidates the previously-cached asset with the given key, so that the next call to getOrCreate will create the asset instead of returning the existing one. | |
| bool | invalidate (TAssetType &asset) |
| Invalidates the previously-cached asset, so that the next call to getOrCreate will create the asset instead of returning the existing one. | |
| size_t | getAssetCount () const |
| Returns the total number of distinct assets contained in this depot, including both active and inactive assets. | |
| size_t | getActiveAssetCount () const |
| Gets the number of assets owned by this depot that are active, meaning that they are currently being used in one or more places. | |
| size_t | getInactiveAssetCount () const |
| Gets the number of assets owned by this depot that are inactive, meaning that they are not currently being used. | |
| int64_t | getInactiveAssetTotalSizeBytes () const |
| Gets the total bytes used by inactive (unused) assets owned by this depot. | |
| void | operator= (const SharedAssetDepot< TAssetType, TAssetKey, TContext > &other)=delete |
Public Member Functions inherited from CesiumUtility::ReferenceCounted< T, true > | |
| std::atomic< int64_t > | inactiveAssetSizeLimitBytes |
| The maximum total byte usage of assets that have been loaded but are no longer needed. | |
| TAssetType | The type of asset stored in this depot. This should be derived from CesiumUtility::SharedAsset. |
| TAssetKey | The key type used to uniquely identify assets in this depot. |
| TContext | The type of context passed to the factory function when creating a new asset. This defaults to SharedAssetContext. This type must contain a field named asyncSystem of type AsyncSystem. |
Definition at line 57 of file SharedAssetDepot.h.
| using CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::FactorySignature |
| asyncSystem | The AsyncSystem used by this SharedAssetDepot. |
| pAssetAccessor | The IAssetAccessor used by this SharedAssetDepot. Use this to fetch the asset. |
| key | The TAssetKey for the asset that should be loaded by this factory. |
Definition at line 91 of file SharedAssetDepot.h.
| CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::SharedAssetDepot | ( | std::function< FactorySignature > | factory | ) |
| factory | The factory to use to fetch and create assets that don't already exist in the depot. See FactorySignature. |
Definition at line 340 of file SharedAssetDepot.h.
virtual |
Definition at line 352 of file SharedAssetDepot.h.
| size_t CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::getActiveAssetCount | ( | ) | const |
Definition at line 513 of file SharedAssetDepot.h.
| size_t CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::getAssetCount | ( | ) | const |
Definition at line 506 of file SharedAssetDepot.h.
| size_t CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::getInactiveAssetCount | ( | ) | const |
Definition at line 520 of file SharedAssetDepot.h.
| int64_t CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::getInactiveAssetTotalSizeBytes | ( | ) | const |
Definition at line 527 of file SharedAssetDepot.h.
| SharedFuture< CesiumUtility::ResultPointer< TAssetType > > CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::getOrCreate | ( | const TContext & | context, |
| const TAssetKey & | assetKey ) |
| context | The context to pass to the factory function. |
| assetKey | The key uniquely identifying the asset to get or create. |
Definition at line 380 of file SharedAssetDepot.h.
| bool CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::invalidate | ( | const TAssetKey & | assetKey | ) |
Anyone already using the existing asset may continue to do so.
If an asset with the given key does not exist in the depot, this method does nothing.
| assetKey | The asset key to invalidate. |
Definition at line 483 of file SharedAssetDepot.h.
| bool CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::invalidate | ( | TAssetType & | asset | ) |
If the asset is not associated with the depot, or if it has already been invalidated, this method does nothing. If another asset with the same key already exists in the depot, invalidating this one will not affect it.
| asset | The asset to invalidate. |
Definition at line 490 of file SharedAssetDepot.h.
| std::atomic<int64_t> CesiumAsync::SharedAssetDepot< TAssetType, TAssetKey, TContext >::inactiveAssetSizeLimitBytes |
When cached assets are no longer needed, they're marked as candidates for deletion. However, this deletion doesn't actually occur until the total byte usage of deletion candidates exceeds this threshold. At that point, assets are cleaned up in the order that they were marked for deletion until the total dips below this threshold again.
Default is 16MiB.
Definition at line 74 of file SharedAssetDepot.h.
