GltfModifierVersionExtension.h
3#include <Cesium3DTilesSelection/Library.h>
4#include <CesiumUtility/ExtensibleObject.h>
5
6#include <optional>
8namespace CesiumGltf {
9struct Model;
10}
11
12namespace Cesium3DTilesSelection {
13
17struct CESIUM3DTILESSELECTION_API GltfModifierVersionExtension
24 static std::optional<int64_t>
25 getVersion(const CesiumGltf::Model& model) noexcept;
26
34 static void setVersion(CesiumGltf::Model& model, int64_t version) noexcept;
35
39 static constexpr const char* TypeName = "GltfModifierVersionExtension";
44 static constexpr const char* ExtensionName =
45 "CESIUM_INTERNAL_gltf_modifier_version";
46
50 int64_t version = 0;
51
58 int64_t getSizeBytes() const {
59 int64_t accum = 0;
60 accum += int64_t(sizeof(GltfModifierVersionExtension));
62 int64_t(sizeof(CesiumUtility::ExtensibleObject));
63 return accum;
64 }
65};
66
67} // namespace Cesium3DTilesSelection
An extension holding the "version" of a glTF produced by GltfModifier.
static std::optional< int64_t > getVersion(const CesiumGltf::Model &model) noexcept
Gets the version number of the given model, or std::nullopt if the model does not have the GltfModifi...
int64_t version
The current GltfModifier version number of the model.
static void setVersion(CesiumGltf::Model &model, int64_t version) noexcept
Sets the version number of the given model to the given value.
Definition Model.h:14
