Cesium3DTilesSelection::GltfModifierVersionExtension Struct Reference
An extension holding the "version" of a glTF produced by GltfModifier. More...
#include <Cesium3DTilesSelection/GltfModifierVersionExtension.h>
Inheritance diagram for Cesium3DTilesSelection::GltfModifierVersionExtension:
static std::optional< int64_t > getVersion (const CesiumGltf::Model &model) noexcept
 Gets the version number of the given model, or std::nullopt if the model does not have the GltfModifierVersionExtension attached to it yet.
static void setVersion (CesiumGltf::Model &model, int64_t version) noexcept
 Sets the version number of the given model to the given value.
int64_t version = 0
 The current GltfModifier version number of the model.
static constexpr const char * TypeName = "GltfModifierVersionExtension"
static constexpr const char * ExtensionName
Definition at line 17 of file GltfModifierVersionExtension.h.
int64_t Cesium3DTilesSelection::GltfModifierVersionExtension::getSizeBytes ( ) const
Definition at line 58 of file GltfModifierVersionExtension.h.
◆ setVersion()
static void Cesium3DTilesSelection::GltfModifierVersionExtension::setVersion ( CesiumGltf::Model & model,
int64_t version )
staticnoexcept
This method creates the GltfModifierVersionExtension and attaches it to the Model if it does not already exist. If it does exist, the version number is updated.
◆ ExtensionName
const char* Cesium3DTilesSelection::GltfModifierVersionExtension::ExtensionName
Initial value:
"CESIUM_INTERNAL_gltf_modifier_version"
Definition at line 44 of file GltfModifierVersionExtension.h.
const char* Cesium3DTilesSelection::GltfModifierVersionExtension::TypeName = "GltfModifierVersionExtension"
Definition at line 39 of file GltfModifierVersionExtension.h.
◆ version
int64_t Cesium3DTilesSelection::GltfModifierVersionExtension::version = 0
Definition at line 50 of file GltfModifierVersionExtension.h.
