Tile.h
5#include <CesiumTilesetJson/BoundingVolume.h>
6#include <CesiumTilesetJson/Content.h>
7#include <CesiumTilesetJson/ImplicitTiling.h>
8#include <CesiumTilesetJson/Library.h>
9#include <CesiumTilesetJson/MetadataEntity.h>
10#include <CesiumUtility/ExtensibleObject.h>
11
12#include <optional>
13#include <string>
14#include <vector>
15
16namespace CesiumTilesetJson {
20struct CESIUMTILESETJSON_API Tile final
25 static constexpr const char* TypeName = "Tile";
26
33 struct Refine {
35 inline static const std::string ADD = "ADD";
36
38 inline static const std::string REPLACE = "REPLACE";
39 };
40
45
51 std::optional<CesiumTilesetJson::BoundingVolume> viewerRequestVolume;
52
58 double geometricError = double();
59
69 std::optional<std::string> refine;
70
82 std::vector<double> transform =
83 {1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1};
84
90 std::optional<CesiumTilesetJson::Content> content;
91
96 std::vector<CesiumTilesetJson::Content> contents;
97
101 std::optional<CesiumTilesetJson::MetadataEntity> metadata;
102
106 std::optional<CesiumTilesetJson::ImplicitTiling> implicitTiling;
107
114 std::vector<CesiumTilesetJson::Tile> children;
115
122 int64_t getSizeBytes() const {
123 int64_t accum = 0;
124 accum += int64_t(sizeof(Tile));
126 int64_t(sizeof(CesiumUtility::ExtensibleObject));
127 accum += this->boundingVolume.getSizeBytes() -
128 int64_t(sizeof(CesiumTilesetJson::BoundingVolume));
129 if (this->viewerRequestVolume) {
130 accum += this->viewerRequestVolume->getSizeBytes() -
131 int64_t(sizeof(CesiumTilesetJson::BoundingVolume));
132 }
133 accum += int64_t(sizeof(double) * this->transform.capacity());
134 if (this->content) {
135 accum += this->content->getSizeBytes() -
136 int64_t(sizeof(CesiumTilesetJson::Content));
137 }
138 accum +=
139 int64_t(sizeof(CesiumTilesetJson::Content) * this->contents.capacity());
140 for (const CesiumTilesetJson::Content& value : this->contents) {
141 accum +=
142 value.getSizeBytes() - int64_t(sizeof(CesiumTilesetJson::Content));
143 }
144 if (this->metadata) {
145 accum += this->metadata->getSizeBytes() -
146 int64_t(sizeof(CesiumTilesetJson::MetadataEntity));
147 }
148 if (this->implicitTiling) {
149 accum += this->implicitTiling->getSizeBytes() -
150 int64_t(sizeof(CesiumTilesetJson::ImplicitTiling));
151 }
152 accum +=
153 int64_t(sizeof(CesiumTilesetJson::Tile) * this->children.capacity());
154 for (const CesiumTilesetJson::Tile& value : this->children) {
155 accum += value.getSizeBytes() - int64_t(sizeof(CesiumTilesetJson::Tile));
156 }
157 return accum;
158 }
159};
160} // namespace CesiumTilesetJson
A bounding volume that encloses a tile or its content. At least one bounding volume property is requi...
Metadata about the tile's content and a link to the content.
Definition Content.h:18
This object allows a tile to be implicitly subdivided. Tile and content availability and metadata is ...
An object containing a reference to a class from a metadata schema, and property values that conform ...
Known values for Specifies if additive or replacement refinement is used when traversing the tileset ...
Definition Tile.h:33
ADD
Definition Tile.h:35
REPLACE
Definition Tile.h:38
A tile in a 3D Tiles tileset.
Definition Tile.h:21
std::vector< CesiumTilesetJson::Content > contents
An array of contents. When this is defined, then content shall be undefined.
Definition Tile.h:96
CesiumTilesetJson::BoundingVolume boundingVolume
The bounding volume that encloses the tile.
Definition Tile.h:44
std::vector< CesiumTilesetJson::Tile > children
An array of objects that define child tiles. Each child tile content is fully enclosed by its parent ...
Definition Tile.h:114
The error, in meters, introduced if this tile is rendered and its children are not....
Definition Tile.h:58
Definition Tile.h:25
std::optional< CesiumTilesetJson::MetadataEntity > metadata
A metadata entity that is associated with this tile.
Definition Tile.h:101
std::optional< CesiumTilesetJson::Content > content
Metadata about the tile's content and a link to the content. When this is omitted the tile is just us...
Definition Tile.h:90
std::vector< double > transform
A floating-point 4x4 affine transformation matrix, stored in column-major order, that transforms the ...
Definition Tile.h:82
std::optional< CesiumTilesetJson::BoundingVolume > viewerRequestVolume
Optional bounding volume that defines the volume the viewer shall be inside of before the tile's cont...
Definition Tile.h:51
std::optional< std::string > refine
Specifies if additive or replacement refinement is used when traversing the tileset for rendering....
Definition Tile.h:69
Definition Tile.h:122
std::optional< CesiumTilesetJson::ImplicitTiling > implicitTiling
An object that describes the implicit subdivision of this tile.
Definition Tile.h:106
