ImplicitTiling.h
6#include <CesiumTilesetJson/Subtrees.h>
9#include <cstdint>
10#include <string>
11
12namespace CesiumTilesetJson {
18struct CESIUMTILESETJSON_API ImplicitTiling final
23 static constexpr const char* TypeName = "ImplicitTiling";
24
31 inline static const std::string QUADTREE = "QUADTREE";
32
34 inline static const std::string OCTREE = "OCTREE";
35 };
36
44
50 int64_t subtreeLevels = int64_t();
51
55 int64_t availableLevels = int64_t();
56
61
68 int64_t getSizeBytes() const {
69 int64_t accum = 0;
70 accum += int64_t(sizeof(ImplicitTiling));
72 int64_t(sizeof(CesiumUtility::ExtensibleObject));
73 accum += this->subtrees.getSizeBytes() -
74 int64_t(sizeof(CesiumTilesetJson::Subtrees));
75 return accum;
76 }
77};
78} // namespace CesiumTilesetJson
Known values for A string describing the subdivision scheme used within the tileset.
This object allows a tile to be implicitly subdivided. Tile and content availability and metadata is ...
std::string subdivisionScheme
The number of distinct levels in each subtree. For example, a quadtree with subtreeLevels = 2 will ha...
The numbers of the levels in the tree with available tiles.
CesiumTilesetJson::Subtrees subtrees
An object describing the location of subtree files.
Definition Subtrees.h:15
Definition Subtrees.h:32
