cesium-native 0.67.0
This object allows a tile to be implicitly subdivided. Tile and content availability and metadata is stored in subtrees which are referenced externally. More...
#include <CesiumTilesetJson/ImplicitTiling.h>
Classes | |
| struct | SubdivisionScheme |
| Known values for A string describing the subdivision scheme used within the tileset. More... | |
| std::string | subdivisionScheme = SubdivisionScheme::QUADTREE |
| A string describing the subdivision scheme used within the tileset. | |
| int64_t | subtreeLevels = int64_t() |
The number of distinct levels in each subtree. For example, a quadtree with subtreeLevels = 2 will have subtrees with 5 nodes (one root and 4 children). | |
| int64_t | availableLevels = int64_t() |
| The numbers of the levels in the tree with available tiles. | |
| CesiumTilesetJson::Subtrees | subtrees |
| An object describing the location of subtree files. | |
| static constexpr const char * | TypeName = "ImplicitTiling" |
Definition at line 18 of file ImplicitTiling.h.
Definition at line 68 of file ImplicitTiling.h.
| int64_t CesiumTilesetJson::ImplicitTiling::availableLevels = int64_t() |
Definition at line 55 of file ImplicitTiling.h.
| std::string CesiumTilesetJson::ImplicitTiling::subdivisionScheme = SubdivisionScheme::QUADTREE |
Known values are defined in SubdivisionScheme.
Definition at line 43 of file ImplicitTiling.h.
| int64_t CesiumTilesetJson::ImplicitTiling::subtreeLevels = int64_t() |
Definition at line 50 of file ImplicitTiling.h.
| CesiumTilesetJson::Subtrees CesiumTilesetJson::ImplicitTiling::subtrees |
Definition at line 60 of file ImplicitTiling.h.
Definition at line 23 of file ImplicitTiling.h.
